No OD, P0715,p0717 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-13-2008, 08:54 AM Thread Starter
GAS
GAS's Avatar
No OD, P0715,p0717
I realize that the codes are for turbine shaft speed, but what sets the codes?
I am trying to figgure out if I have a hard part problem that requires a new trans or if it is a control/valvebody issue that can be repaired?
Going down the freeway it shifted out of od to third all of a sudden and heard a loud chatter,ginding noise? Could this all be a TC problem?
Fluid is pink and up to level,
I am thinking it is possible that I caused the codes when I shut of the engine while coasting and restarted it, hoping to reset things.
Hope this all makes sense
Micha
GAS is offline
post #2 of 5 Old 07-13-2008, 09:25 AM
CoalRollinRoosterCruiser's Avatar
Fill in your sig. with info on your truck
Year, engine, mods, etc. etc.
Jonathon or John Although technically i have a list of nicknames the length of I-95, so call me what ya like
Current Truck--1999.5 F350 ext cab short bed SRW Lariat 4x4 ZF-6. 4" lift, 35's, exhaust, intake, chip, and more.
CoalRollinRoosterCruiser is offline
post #3 of 5 Old 07-13-2008, 03:47 PM Thread Starter
GAS
GAS's Avatar
Will do!
I just got done pulling the pan on the trans,, I'm screwed
Metal flakes!!
Trans is out and ready to get torn down/replaced.
Any one have feed back on Fords Heavy Duty Reman??
Thanks
Micha, Pleasant Grove, Utah
99 F350 Crew cab long bed, Tymar intake(The real deal)
Zoodad, 4 inch exhaust, Dipricol gauges, WW,
gutted turbo pedestal and ebpv deleted big exhaust outlet, ccv delete
GAS is offline
post #4 of 5 Old 07-13-2008, 04:06 PM
Other vehicle is an F250
Hank's Avatar
I'd contact some local sled pullers/drag racers and see who builds there trannies. I am on my 3rd Ford tranny with 117,000 miles. I'd look somewhere else besides Ford if it were me.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #5 of 5 Old 07-13-2008, 04:50 PM
Go with a John Wood or BTS Transmission.
You WILL NOT regret it, and it will definitely be worth it.
