911 help 4x4 low - Ford Powerstroke Diesel Forum
post #1 of 4 Old 09-08-2013, 10:30 AM Thread Starter
switchmaster's Avatar
911 help 4x4 low
2008 f450 stuck in 4x4 low. Put truck in 4x4 low to back trailer on grass because tires were spinning now stuck in new York. Can only go 25 mph and it's Sunday. Please help my number is 219 210 7022 if someone could walk me through a vacuum line check or fuse check. Thank you Jeremy
If you don,t want to stand behind our Soldiers feel free to stand in front of them.
switchmaster is offline
post #2 of 4 Old 09-08-2013, 10:55 AM
Doesn't Even Care
HVAC SuperTech's Avatar
Quoted: 69 Post(s)
did you put in neutral and then try to turn switch back to 2wd? try turning the truck off and re cranking the truck. make sure hubs aren't in the locked position. does the 4lo go off the dash or whatever? (I DONT KNOW IF IT LIGHTS UP ON THE DASH, I HAVE A 99) If the light goes off, but still wont come out, try looking under neath the truck and make sure the wire is plugged into the transfer case motor and tap on the motor. might be stuck there
Nick
E99/CC/Lariat/Factory Wide Body Kit
"The Mistress"
Power Hungry Performance HYDRA Chip
Custom Tuned by Bill@PHP, Tony Wildman@Total Diesel Performance and Lars@Gearhead
D66 w/Dieselsite WW2, Full Force 250/100s, Adrenalin HPOP, Built Trans, Walbro Fuel Pump, S&B Intake, 6" Stacks, Leveling Kit, Eagle Alloy Wheels, 315/75/16 Grabber AT2s & Much More
HVAC SuperTech is offline
post #3 of 4 Old 09-08-2013, 11:19 AM Thread Starter
Thank you, that fixed it
I let it set for a few and turned it back on and it reset to 2wd and it is fixed, thank you for the 911 speedy reply, I love this site and the people in it, thanks again
post #4 of 4 Old 09-08-2013, 12:42 PM
Doesn't Even Care
Quoted: 69 Post(s)
Sure thing buddy. Glad to get you going again!
Sent from AutoGuide.com App
Nick
"The Mistress"
