2005 6.0 auto trans suddenly running way too hot - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-24-2013, 03:48 PM Thread Starter
Does anyone have an idea why suddenly overnight (after picking my truck up from the shop for motor work ) the auto trans is spiking the trans temp gauge
and the scanner is saying 245 deg F under no load normal diving !
joebobrocker1967 is offline
post #2 of 12 Old 08-24-2013, 05:08 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Welcome to the site. I would do what is called a cold soak. Let the truck sit over nite. Then on a cold start check your temps . They should all match.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 12 Old 08-25-2013, 08:40 AM Thread Starter
Will Do !
Good idea
Thanks a lot.
post #4 of 12 Old 08-25-2013, 10:05 AM Thread Starter
I turned the key to on position and the dash gauges barely move which seems normal.
The scan gauge reads 81 deg F for all fluids.........
now what ?
post #5 of 12 Old 08-25-2013, 10:25 AM
ZMANN's Avatar
Quoted: 1466 Post(s)
I am thinking it's the in pan senderor related wiring ? not that a trans issue is out but
your coolers don't even come into play until over 180ish
the previous recommendations were good but now
if it were Me I would heat gun the pan and see if it is actually that high
how fast does it peg the gauge ?
We Miss you Ronnie
ZMANN is online now
post #6 of 12 Old 08-25-2013, 10:43 AM Thread Starter
It takes about 20-30 min to get to what the sensor is saying is 250 deg f.
I suppose I could drive it, get it "hot" , get under and drain some fluid or put a pyrometer to the pan and see what it reads.
Thanks for the reply
post #7 of 12 Old 08-25-2013, 11:49 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I was snoopin around under there one time and thought I saw a very easy place to install a manual temp guage type set up that you could buy at any auto store. Check that out. Could be a easy way to get the fact cconfirmed or denied.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 12 Old 08-25-2013, 12:15 PM Thread Starter
suddenly overheating tranny
I'm hooking up a digital thermocouple temp reader I use at work that's super accurate right now as we speak.
Thanks again
post #9 of 12 Old 08-25-2013, 08:50 PM Thread Starter
I drove the damn thing and the temp slowly started to climb to 235 deg F.
Hooked up a digital thermometer to the coolant ( stuck it in the degass bottle) and compared it to what the scan gauge was reading to get a sense of accuracy and calibration so to speak. Then crawled under the beast in the 110 deg heat of so cal and the temp said 225 deg f almost matching the scan gauges readings. I said screw it and figured a fluid change wouldn't hurt anyways so dropped the pan and it looked clean.
Replaced the TFT sensor for $15, filters, etc....put it all back together and it still does the same thing ! Still overheating ! Never, ever ran over 185 even towing hard up hill in death valley.........weird it only stated doing this right after getting it back from the truck shop. Just my luck.
post #10 of 12 Old 08-26-2013, 07:17 AM
I would suggest that since your trans temp was fine before the work was done on your motor that your problem may be associated with that work. I would go through and check all the wires, connectors and so on to make sure your motor was done properly.
99.5 F250 7.3 (Sold)
2006 F350 6.0 CC LB SRW FX4
Pro Comp 2.5 Leveling Kit
New Premium FICM from Ed
IPR GEN 2 EGR Delete w/ Up Pipe
Flo Pro 4" Turbo Back w/muffler
Blue Spring Mod
SCT Livewire ts
Ag Street Tune by Eric
NCDeerHunter is offline
