Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 10-18-2006, 07:56 PM
MNDIZZLE MNDIZZLE is offline
Fail Safe Mode?
I had a remote starter installed today. When they picked up my truck it ran perfect. When they dropped it off the overdrive light was flashing, the truck feels like it's starting in 3rd gear, and I have 4 trouble codes in my HyperPac all transmision related. The jack-off that delivered it to me said that it feels kind of sluggish. He said that sometimes when you put big tires on big heavy trucks they get a little sluggish. I had to refrain from kicking him in the teeth!
I left the truck at work to avoid driving it. They said they'll come pick it up tomorrow and try to figure it out. Should I let them drive it back to their shop? Is it in limp mode? What do I do?
Old 10-18-2006, 08:42 PM
sea-level sea-level is offline
Sounds like they failed to hook up all of the ignition and accessory wires. When those particular wires aren't ALL hooked up the truck will fail to ignite them when you put your key in. Did you try starting the truck without using the remote start? Exactly what kind of truck is it?
Old 10-18-2006, 10:20 PM
It's an '03 7.3 F250. I tried starting it without the remote start but it still did it. i also cleared the codes, but they came right back. Shift solenoids and torque converter electrical codes. I'm just afraid to let them drive it. It's about 10 milles from their shop to my work.
Old 10-18-2006, 10:29 PM
mschn99 mschn99 is offline
since the codes started with the instal, i would definately make them attempt to fix it and then send it to the dealer and let them prove it was the fault of the aftrmarket....either way im sure it will prove the install was the problem
Old 10-19-2006, 12:05 AM
gcop gcop is offline
PIPE HITTER
What brand of remote start is it? Is it remote start only?
Old 10-19-2006, 05:15 AM
It's a Compustar 2 way pro series. Has alarm option but I just have it as a remote start.
Old 10-19-2006, 05:36 AM
I would have the place check the wiring. Definitely sounds like they failed to hook up the 2nd or 3rd ignition which powers the transmission. The only other thing you might try is disconnecting the battery for about 10 minutes and then try starting it with out using the remote start. If that doesn't fix the problem, they could have damaged the ECU or might have just pulled something loose.
Old 10-19-2006, 05:45 AM
Try checking all of your fuses too, including the ones under the hood.
Old 10-19-2006, 07:10 AM
They came to pick it up at work this morning. Sounds like they forgot to hook up some wires to power the tranny. I'm a little concerned about them driving it from their shop last night. It's about 10 miles uphill. I'm worried that after they hook up the wires and the tranny starts working again, that I'm going to have problems with it. Would driving it up here with the trans in 3rd gear cause any damage to the torque converter? I would imagine they had to throttle it pretty hard to get it up the hill. ???? I feel like my child was just raped!!!
Old 10-21-2006, 07:58 PM
Urayo Urayo is offline
You can probably damage your TC shaft seals, because the solenoid body is not regulating the correct pressure and you might end with to much pressure inside the TC, check if you have any tranny leaks cause by over pressure. It happened to me and I end up replacing the solenoid body’ lucky for me I didn’t damage the shaft seal.
