P0783 about to pass into Canada. Help! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-29-2013, 06:42 PM Thread Starter
Guys I just got the p0783. Blinking od light and no noticeable issues. Trans temp has never been over 190 and when it started it was at 160. Fluid is at right level and cherry. Trans shifts just fine. Should I be freaking out? I'm on my way to Alaska and a far way from anyone I know
Thanks
-Jake
Stolher is offline
post #2 of 4 Old 07-29-2013, 07:00 PM
alaskan155's Avatar
Quoted: 60 Post(s)
when i typed it in the search box it said the 3-4 shift solenoid ford that code for the 4r100,
so i am going to assume you have a 7.3?
sounds like it could be a few different things, but basically sounds like you lost overdrive
since you are far away, try clearing the code and checking the connector on the transmission for corrosion, maybe you will get lucky and its just a short.
where are you going in at? if Seattle you can take the ferry up if you have the money(a little expensive, but might be a option if your on a tight deadline to get up there)
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #3 of 4 Old 07-29-2013, 07:10 PM Thread Starter
Sorry. Yeah 7.3. The weird thing is, I have overdrive. I haven't been using it for fear of damaging something. Any idea which solenoid it is? I'm going up through n Dakota and catching the alcan
Stolher is offline
post #4 of 4 Old 07-29-2013, 08:43 PM
alaskan155's Avatar
Quoted: 60 Post(s)
my bet its on the way out then/a short, basically at somepoint the ecm told the computer to shift to OD and the trans didn't, so it threw the code,
you aren't towing are you? heard that could throw the light if the tranny is getting a little old and slipping
if OD is working and not slipping i would just take it easy and head on up, looking online it looks like you have to drop the valve body to fix it, and thats assuming there is nothing else wrong internally with the trans..
but it on your discretion, haha just basing what i found online/ trying to help you out, the final decision is on you.
i know ND is going to be expensive to have a shop fix it, so if you can, try to take it over to billings, MT if you want to repair it before hand(used to work in north dakota)
