Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 04-21-2008, 05:42 AM
davand davand is offline
1993 F250 7,3 auto will not select 1st gear
Hi! I have to select 1st instead of Drive to get the truck moving, then move the selector back to Drive. Everything else works fine. I gears nicely through all gears and Reverse works as normal. It happened pretty instantly, but no noises.
There is a little too much oil on the tranny, could that be the reason?
I have never had any tranny problems, but two weeks ago, while towing on a long hill, I forgot to push the button on the gearselector and it went into sefety mode. It was also a little low on oil, so I added a little oil and removed the battery connections to reset the tranny and everything worked nice until today.
It seems like a gearselector problem to me but I dont know. Can anyone help?
Thanks!
Old 04-21-2008, 07:42 AM
just found out that if i select Drive, the trucks tries to drive off in 3rd. Then, if I rev i quite a bit, it goes into 1st and pulls off normally.
The oil is red,clear and nice but maybe oil and filter change is whats needed??
Old 04-21-2008, 10:55 AM
also, can I use the truck or should I wait until I know what is wrong with it?
Old 04-22-2008, 11:22 AM
drstephennix drstephennix is offline
Always Remember
Send a message via Yahoo to drstephennix
Old 04-22-2008, 03:10 PM
I don't understand what your reply mean!
Old 04-25-2008, 03:12 PM
changed oil and filter today. no particles or anything unormal in the pan. the truck stil wants to start i second instead of first though
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
