Another 5R110 Question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-20-2013, 09:39 AM Thread Starter
ejg3855's Avatar
So I get the delay to reverse and then the shudder while going in reverse.
I also get some gear hunt and shift flare until the TC locks in on the highway.
I am trying to decide if its a gearbox or a TC problem.
THoughts, help?
ejg3855 is offline
post #2 of 6 Old 06-20-2013, 09:45 AM Thread Starter
ejg3855's Avatar
sounds like it might be a direct drive solenoid?
ejg3855 is offline
post #3 of 6 Old 06-20-2013, 03:53 PM Thread Starter
ejg3855's Avatar
I get P2703 when I scanned for codes.
ejg3855 is offline
post #4 of 6 Old 06-21-2013, 05:17 AM Thread Starter
ejg3855's Avatar
good thing this is the 911 forum.
ejg3855 is offline
The Following User Says Thank You to ejg3855 For This Useful Post:
BuschCountryBoy (08-05-2014)
post #5 of 6 Old 06-21-2013, 05:23 AM Thread Starter
ejg3855's Avatar
Called MTS and they seem to think the trans is junk, says the DCS would just be a bandied.
ejg3855 is offline
post #6 of 6 Old 06-21-2013, 05:33 AM
theswoleguy's Avatar
Quoted: 8 Post(s)
Garage
sounds like you may have answered your own question... best of lucky with a new transmission. build it right the first time.
2005 F250 Fx4, Crew Cab, King Ranch
8" Procomp Lift w/ ext. reservoir shocks, Trac Bars, 22x14 Fuel Mavericks, 38x15.50 Fuel MTs, O-ringed heads w/ valve job, studded, 5" exhaust, Fass Ti w/ RR, XDP Sump, Coolant Filter, Singer 270Amp Alt, BPD 58v FICM, S&B Intake, Powermax, S&B intake Elbow, Snow WMI, ID Tunes, TSD tunes, PHP Ficm Programmer (Atlas 80 majority of the time), Mishimotor Radiator & Intercooler, BPD Water Pump, Gates HD Serp Belt, Flex-a-lite E-Fan Conversion
theswoleguy is offline
