Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 03-13-2008, 07:48 AM
Stroker7.3 Stroker7.3 is offline
broke
My truck just took a sh!t!!!! Driving last night took a turn up a hill when i tried accelerating the truck had no power and stopped at 25 mph. it would surge like the rpms would rev up and down on there own. i florred the acclekretar and would not go faster then 35 mph. something seriosly wrong. chips are off. neeed help asap was going to moab next week.
thanks
Old 03-13-2008, 07:54 AM
willholl79 willholl79 is offline
How does it run at idle?
Old 03-14-2008, 03:57 PM
well at idle it felt like it was missing. but i got it fixed. i had low oil (my fault lol) so it was foaming causing my injectors to malfunction killing cylinders...
Im so glad it was an easy fix
Old 03-14-2008, 04:01 PM
sevenmalards sevenmalards is offline
That's OFFICER McKown 2U!
So that was the problem and fix, low oil?
Old 03-14-2008, 08:01 PM
ya so far it hasnt done it since... did an oil change and its ran fine since then so i guess low oil is a big problem in powerstrokes.
Old 03-15-2008, 01:29 PM
Well it is because the injectors run off of oil pressure, that way if you have some kind of catastrophic failure and loose all your engine oil (punch a hole in your pan or something) the motor will quit and not burn up. I've heard of the problem you've had, you must have been pretty low. I've had mine a couple quarts low and it didn't happen.
Glad it was something easy....and CHEAP!
Old 03-15-2008, 01:39 PM
ford99PSD ford99PSD is offline
good fix and at least you didnt have a major prob, my truck seems to eat oil untill it gets to be about 1.5 qt low, i dont know whehe it goes and i never see any leaks but when i add oil after about two weeks its back to being low... wtf?
