4x4 1 tire in front spinning 1 in back. stranded - Ford Powerstroke Diesel Forum
post #1 of 16 Old 05-23-2013, 11:01 PM Thread Starter
so im out looking for a fishing spot, i go through this fairly deep mud hole, i had the hubs locked and made it through with ease.. on the way back, i go through the same mud hole but come to a complete stop, i get out and im high centered bad but my passenger tire is on very dry ground it isnt even burried.. hubs are still locked im in 4 high, and my driver side frnt and passenger rear are the only 2 tires spinning, i am in the middle of nowhere and ended up leaving my truck in the bush.. what should i be worried about replacing once my truck is pulled out im 6 hours from home but should be able to get parts
lrgnugs is offline
post #2 of 16 Old 05-24-2013, 12:03 AM
Wannabitawerm's Avatar
4 wheel low should load up the diffs enough to lock em.
Sent from AutoGuide.com App
Wannabitawerm is offline
post #3 of 16 Old 05-24-2013, 01:06 AM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
Sounds like nothing is broken, you just need to have some lockers or good limited slip differentials installed in your axles!!!
With the stock open differentials, power only ends up going to one wheel on each axle when you get in the soft stuff. So it's not really a true 4x4 until you do this.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #4 of 16 Old 05-24-2013, 04:09 PM Thread Starter
I got it out with a picker truck that had a 22000 lb winch but bent my steering stabilizer shock and it's leaking now, will I be fine to drive it? I've taken it up to a 100 km/hr no wobble but it's leaking fast
lrgnugs is offline
post #5 of 16 Old 05-24-2013, 04:22 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
sounds like your steering stabilizers toast anyways.
as long as its not binding when you turn just wait tell you get home.
and ya these things are one wheel wonders lol factory lsd out back isnt the greatest. and front is open diff
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #6 of 16 Old 05-25-2013, 07:19 PM Thread Starter
thank you guys for all the help, everytime i turn to this website the advice has been phenominal
lrgnugs is offline
post #7 of 16 Old 05-25-2013, 11:09 PM
JSchuricht's Avatar
Low range has nothing to do with having open differentials.
JSchuricht is offline
post #8 of 16 Old 05-27-2013, 05:48 PM
On my 2002 350, if I load it up using the throttle, they lock.
post #9 of 16 Old 05-27-2013, 11:45 PM
JSchuricht's Avatar
Then your truck isn't using stock differentials. For the diffs to lock under load you would need a mechanical locker. Ford has offered a limited slip in the rear but it doesn't lock under load. The closest thing Ford offers is a electronic locker IIRC in the 08+ trucks for the rear only but that doesn't lock under load, it's electrical. Ford has no options for the front other than the open carrier wich means the wheel with the least amount of traction will turn.
post #10 of 16 Old 05-28-2013, 12:11 AM
Rodslinger's B1TCH
if you put you brakes on slightly while giving it throttle, you might be able to equalize pressure between the two sides and get just enough traction to get out.
I used to do this all the time with my limited slip diffs when I needed a little more traction in the rear. put the e-brake on one click at a time while holding steady on the throttle and you might be able to get a 2 tire fire.
I few years ago I decided to go with a completely different truck that is set up better for off-road with a locker. the superduty is a great highway tow truck....
steve604 is offline
