Tranny in LIMP Mode, NO Start P0706 code - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-21-2013, 08:23 AM Thread Starter
This weekend while pulling my boat (5k lbs) my truck started making a clicking noise in the dash where the fuses and relays are. It acted like it couldn't decide what gear it wanted to be in while decelerating, kinda shifting into neutral. Check engine light came on, tow haul light started flashing, went into limp mode and the clicking stopped. When I tried to start the truck after eating dinner, no go. Jumped the starter from the connector on the passenger side. The dtc is P0706. I'm sure its either the TRS or the harness in the trans itself, but where to start would be great.
'07 6.0 F250, SCT Custom, Volant Cold Air Intake, 5" turbo back no tip, ARP studs, Sinister EGR delete kit, HP fuel Pump, 35x12.50x18 Toyos---- bigger injectors in the works
HeadJerker211 is offline
post #2 of 3 Old 08-19-2015, 05:55 PM
i have same problem, any luck?
jackrabbit is offline
post #3 of 3 Old 08-19-2015, 05:58 PM
same issue
my 06' 6.0 has the same issue. Im thinking of replacing the whole transmission range sensor unit. Any tips or advice on what you found out?
