2002 7.3L 4x4 auto trans diagnose - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-03-2013, 09:53 AM Thread Starter
checked my fluid 3ish weeks ago, red, smelled like it should, about a week ago the truck seemed to be searching for gears, i stopped put it in park back in drive everything was fine, hauled a load of scrap metal 700lbs in the bed, leaving the yard it started having trouble going from a stop. had to rev up to about 1200 rpms and it would be hardly moving then be normal, this lasted maybe 5 stops and then back to normal. tightened the linkage and it seemed like everything was resolved although drove around till i reached operating temps no issues untill i started heading home, seemed to be needing higher rpms and lacking power thru 1st. leave the truck running pull the dipstick fluids black, smells faintly of burning... 1) would I be able to pull any trouble codes that would tell me about the trans functioning 2) is there a way to be %100 sure the trans is my issue? 3) anyone in the chicago land area able to recommend a shop for a rebuild? 4) would it be worth my time to dismount the trans myself and bring it in without the truck?
steve349 is offline
post #2 of 4 Old 05-03-2013, 10:04 AM Thread Starter
appreciate any help you guys can give me
steve349 is offline
post #3 of 4 Old 05-03-2013, 12:02 PM Thread Starter
just had autozone look for stored trouble codes they didn't find any unfortuneatly
steve349 is offline
post #4 of 4 Old 05-06-2013, 08:19 PM
need to go to a trans shop were they have a better scanner.
smoke on this is offline
