I think i blew my buddy's transmission....HELP - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-29-2013, 12:39 PM Thread Starter
OK, the background.
2000 Ford F-250 with 7.3 Diesel, long box, 4 door, automatic trans, stock everything except a Diablo Sport set to tow mode
So I just bought a new camper (30ft travel trailer, 7000lb dry but was probably around 8000lb that day loaded) that my buddy was delivering to my land for me.
I have a hill that's probably 10' of rise over 20' run...i would guess 30-35degree angle. A person can walk the hill without much effort and i can drive my Chevy Tahoe and Chevy Sonic up it without any issues.
The only option was to back the camper straight up the hill. So he was in 4 low, OD off. So he backed it up and the trailer tires were just about to break the crest of the hill when he had to stop so i could trim a branch that was about to hit the AC on the camper. So after i did that, he backed it up another 15' so now the camper was on the top of hill but the hitch was right at the crest of the hill. This is where his tires started to slip a bit. When he went to give it the 3rd push back that's when there was smoke.
No fluid was dripping out at any point and the only gear he has is park.
Any suggestions??
willie1280 is offline
post #2 of 9 Old 04-29-2013, 12:47 PM
buckels's Avatar
Send a message via AIM to buckels Send a message via MSN to buckels Send a message via Yahoo to buckels
Did you check to make sure that the Transfer case didnt slip out of gear? I have had that happen once.
Drew
99 SD 6SPD manual
AFE Intake
Diamond Eye 4" turbo back exhaust
Wicked Wheel Gen2
PHP Hydra tunes by Bill
If you live in WA or OR check out these links.
buckels is offline
post #3 of 9 Old 04-29-2013, 12:50 PM Thread Starter
Sorry, i'm not mr.mechanic by any means and the knowledge i do have it related to Jeeps. So how would i check the t-case? Or are you saying to just try the other buttons?
post #4 of 9 Old 05-08-2013, 06:34 AM
Did you check the transmission fluid level?
Owner/Founder of Georgia Diesel Power.
Current Sponsors: QuickTricks Automotive, Ray Paul Powdercoating, Ace Transmission, SoCalTrucks.com
Current Member Count: 16
TheRobenator is offline
post #5 of 9 Old 05-08-2013, 09:56 AM
buckels's Avatar
Is it a manual transfer case with the shifter in the floor or is it buttons? If it has the buttons on the dash I dont know how to check it.
Drew
99 SD 6SPD manual
AFE Intake
Wicked Wheel Gen2
buckels is offline
post #6 of 9 Old 05-08-2013, 10:32 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
If there was smoke, I doubt it was the t-case, unless he has an exhaust leak. And if he only has park...makes me think a smoked pump
Sent from AutoGuide.com App
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #7 of 9 Old 05-08-2013, 10:47 AM
buckels's Avatar
missed the part where he said there was smoke. I have to agree with Tony there.
Drew
99 SD 6SPD manual
AFE Intake
Wicked Wheel Gen2
buckels is offline
post #8 of 9 Old 05-09-2013, 06:38 AM
On the 2000 F250 transfer-cases, if there was just smoke, it was not the t-case since you would have heard a lot of grinding and not just smoke! lol
The best thing you can do as of right now is help us diagnose it for you.
Take the dipstick out and check the fluid level with it running in park. IF that is good, smell the fluid, if it smells burnt, then that is a clear indicator you burnt up something within the transmission.
Next, drain the transmission into a 5 gallon bucket, after that is done, pull the pan and look in it to see if there are any clutch fibers, if there are clutch fibers, you burnt up one of your drums, more then likely the first reverse gear drum which I also believe is first gear as well.
IF YOU SEE METAL SHAVINGS, you burnt your pump more then likely or snapped something else internally. I can pretty much tell you that if the fluid is burnt with no gears, it will need a rebuild. Rebuilds for the 4r100's can run anywhere from $2,500 to $3,300 depending on what is broke inside.
Hope this helped.
post #9 of 9 Old 05-09-2013, 06:58 AM
ZMANN's Avatar
Quoted: 1344 Post(s)
And you didn't burn up His tranny
it was on it's way out
it should have been able to pull that hauler no problem
We Miss you Ronnie
ZMANN is offline
