Trans Problem? Need help fast! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-07-2013, 01:49 PM Thread Starter
Exclamation Trans Problem? Need help fast!
I have a 2004 powerstroke. trans has been serviced normally. i was driving down the road and i noticed it not wanting to take off and it would rev up. then it had stopped moving. i got it home and checked the trans fluid and its fine. it wont move forward but will move about 15 feet in reverse. it wont move forward it just free revs. im not 100% convinced its the tranny but maybe the selinoids or pump? i had the computer flashed but that didnt work. any suggestions as to what it might be? or where to check first?
2004Powerstrokee is offline
post #2 of 4 Old 04-10-2013, 07:03 AM Thread Starter
anything today?
post #3 of 4 Old 04-12-2013, 09:24 AM Thread Starter
i had talked to a ford mechanic and he said it might be the plug from the computer to the trans or maybe the selinoid in the pan or the pump. any suggestions?
post #4 of 4 Old 04-23-2013, 06:45 AM
You could have a bad solenoid, a bad pump, a bad torque converter or a busted drum along with some other things. What is the pressure reading?
Also scan it and give me the codes.
Owner/Founder of Georgia Diesel Power.
Current Sponsors: QuickTricks Automotive, Ray Paul Powdercoating, Ace Transmission, SoCalTrucks.com
Current Member Count: 16
TheRobenator is offline
