Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 01-30-2008, 07:04 AM
stroker27 stroker27 is offline
this is my 3rd tranny!
i just put my third tranny in a couple weeks ago now its having problems again if i put it in drive, it will NOT go past 1st gear. if i then shift the selector into 2nd it goes into second just fine w/no slip or slam. then i shift into d/od and it goes into overdrive. so i basically have 3 gears and i have to manually shift them. what would cause that? no slips or slams anytime i shift it just doesnt do it by itself.
Old 01-30-2008, 07:08 AM
Banshee34 Banshee34 is online now
Ms. Independent
Bumping this up for ya!
Did a shop do your trannies?
Old 01-30-2008, 07:12 AM
i had a shop in TN rebuild them but i did the installs...it was working great until yesterday morning then it wouldnt shift... i didn't do anything i dont normally do as far as using the truck
Old 01-30-2008, 07:17 AM
Ms. Independent
Well I am by no means a tech, so one of them should be along soon to help you out!
Old 01-30-2008, 07:29 AM
oh yeah i should add... i smelled something electrical burning/melting on the freeway the day before this happened. is there a fuse or something that will keep it from shifting right? maybe a short somewhere?
Old 01-30-2008, 07:45 AM
REDPOWERSMOKER REDPOWERSMOKER is offline
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
:BUMP: FOR YA HOPE YOU GET IT FIGURED OUT
Old 01-30-2008, 07:47 AM
cchase cchase is offline
hey my new trans did that when I first put it in. the guy that did it took it back, said a part was in backwards on the valve body, and replaced the computer thats by the pan.
Old 01-30-2008, 09:47 AM
hey thanks for the help guys. i climbed underneath and found a spot where the wiring harness was rubbing the front driveshaft... it had a couple of broken wires so i fixed them and that took care of the tranny shift problem. now. but the electronic 4x4 still wont turn on... maybe i blew a fuse? does anyone know where the fuse is for the 4x4? it did blow my reverse lights fuse and i found and replaced that but it didnt fix the 4x4 not goin in.
Old 01-30-2008, 06:45 PM
bump, cause I dont have any idea. but I will go out and check my manual in the morning if no1 helps.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
