any ideas????? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-17-2013, 09:05 PM Thread Starter
Exclamation any ideas?????
ok so I have 99 7.3 powerstroke and the transmission was working fine then it this started to slip and before I got it home it was slipping so bad it was it was going about 35mph at 3000 rpm. after getting I turned it off when in the house for a few minutes then when out to look at the truck and it would not go in to reverse insted it seems to be stuck in drive. the oil smells burnt so it is trashed. how hard is it to rebuilt it myself?? and can a basic overhual kit fix it or do I need to order more????
nicrw is offline
post #2 of 2 Old 03-17-2013, 10:12 PM
Rodslinger's B1TCH
take it to someone for a rebuild, don't attempt it yourself unless someone is there to show and tell you what you need to do/inspect. if you can re&re it yourself you'll save a few bucks. just bring the transmission to the shop that rebuilds them.
steve604 is offline
