Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 01-19-2008, 01:17 PM
draginwagon draginwagon is offline
02 7.3 6spd clutch snafu!
Ok, any help here would be greatly appreciated. I have owned this truck about 3 months now and have had nothing but great things to say about it. However... today at lunch I grabbed reverse to leave and when I tried to put it in first it was like the clutch wasn't engaged all the way. (kept chugging in reverse. these things just wont stall) I killed the motor with the key, jammed it in neutral and tried again. Drove as normal for 10-12 shifts. Then the same thing again. 10-12 normal shifts stuck again. Is this a hydraulic issue? I cant see a hydraulic problem being intermittent. There were NO noises from the clutch-tranny at any time.
Sorry for the long post.
Again any help would be great!
02 7.3 6spd dually flatbed (6spd= granny 5spd?)
Old 01-19-2008, 08:14 PM
Cj Ford Cj Ford is offline
yes its sounds like a issue with the slave cylinder.. that's the only thing i can think of that will make the clutch not disengage
Old 01-20-2008, 07:49 PM
lilredpowerstroke lilredpowerstroke is offline
Ballin' on a budget
Slave here too!!!
Old 01-20-2008, 07:52 PM
DocB DocB is offline
Yes, check/replace the slave cylinder.
Old 02-28-2008, 07:12 AM
spuds99 spuds99 is offline
Same thing happened to me, was the Slave 100%. Easy to do also!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
