Critter damaged wiring harness - Ford Powerstroke Diesel Forum
post #1 of 1 Old 02-06-2013, 05:25 PM Thread Starter
tomtom's Avatar
Had a cat and dog fight. Cat crawled in engine compartment at shock tower on drivers side. 2002 F350 4x4 Auto. Damaged oil bypass lines coming out of block. Fixed that. Unplugged engine heater fixed that. Unplugged vac line going to front hub. Fixed that. Broke abs sensor line. Fixed that. Unplugged something from bottom of master cylinder. Fixed that. Now I am getting a flashing od light. Pulled codes before fixing anything and I got the following: p1249, p1211, p0708, p0713. Cleared all codes and am still getting a flashing od lite. No codes came back. Tried a different scanner still no codes. Drove truck a short distance and it shifts funny. Tranny temp gauge on dash is not moving. Aftermarket gauge is registering. Any ideas where to start. Visual inspection of all wiring on inner fender seems to be intact. No obvious damage to wires. A wiring diagram would help. Thanks.
2002 F350 DRW CC 4X4 Lariat 7.3
Stock except for Banks Brake and Timbrems
with 50K original miles
FS 2500 bypass filter
Coolant filter
Tranny filter
ISSPRO gauges water, tranny, pyro, and boost.
AIS FTVB 6.0 cooler CCV mod
Zoodad mod
PHP 6 position chip stock, 25 tow, 40 tow, 65 tow, 80 daily driver, smoke show. WOW!
tomtom is offline
