Trans slip Code -- What to do? - Ford Powerstroke Diesel Forum
Old 11-19-2007, 03:54 PM
My 1996 F250 7.3L TD E4OD 4x4 is setting Code P1728.
I can clear the code and it will shift normally until it gets to the point where it should lock-up the converter then sets the code. I had to drive 300+ miles to get it home and it made it ok but I'm at a loss on this. The code says Trans Slipping but it shifts so normally after clearing the code. A couple days ago it set a KAM and P1728. And about a month ago it set a Turbo boost code & P1728 ( I can't find the number I wrote down for that turbo code) when it did that I pulled the pan and changed the oil & filter and drained the TC too and all was well until now. There was no steel or brass or aluminum particles in the pan or on the magnet and the trans oil didn't smell burnt nor did it look bad. It really was very clean inside.
Is there a solenoid or relay or something that could be a problem? Does this sound like a path that some of you have experienced before? The truck has 223K miles on it and is maintained religiously with the normal oil and trans services done more often than necessary and the trans fluid always comes out looking great and no burnt smell or anything metallic in the pan or on the magnet.
Any help with this will be greatly appreciated. If anyone needs more info describing this just let me know.. thanks a lot in advance.
behoof
Old 11-19-2007, 10:25 PM
bump for some help
Old 11-20-2007, 05:02 AM
Bump???
Originally Posted by willypscustoms View Post
bump for some help
Not sure what you mean by "Bump for some Help"?
I'm really stuck with this truck acting up so I sure hope someone with experience with this problem can help.
This is my only transportation and need it pretty bad.
Thanks
Old 11-25-2007, 12:09 PM
Unhappy
behoof
I've done a ton of reading and searching and it seems probable that I'm going to have to replace the TC and/or front pump and maybe disassemble due to possible cloudy fluid / contamination? I got this article while searching the web and it really describes my condition in the first part of the Service Procedure.
03-21-12***STALL - WHEN REVERSE AND/OR MANUAL LOW ARE SELECTED - (DTC) P1728 - OVERDRIVE CANCEL LAMP ILLUMINATED - 7.3L DIT ENGINE - VEHICLES WITH E40D TRANSMISSION - VEHICLES BUILT PRIOR TO 9/20/95***TRANSMISSION - E40D - 7.3L DIT ENGINE - OVERDRIVE
Have any of you dealt with this issue? If so, what did you find? Am I on the right track or is there something I'm missing ?
Also, where would be a good place to get a TC and pump and shaft? I'm in SE Lower Michigan, the Port Huron Area.
Would really appreciate any help or info, thanks in advance,
Skip aka behoof
Old 12-21-2007, 03:52 PM
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
P1728 Description:
Transmission Slip Error -- Converter Clutch Failed
Key On Engine Off:
§ Refer to the Powertrain/Transmission Group in the Service Manual for diagnostic procedures.
Key On Engine Running:
Continuous Memory:
this is all i've found from my book on disk so far and i will keep looking but it sounds like it could be a bad sensor. i also will be with a very smart mechanic in the next couple days and will hit him up too.
Old 03-28-2008, 06:26 PM
Did you ever figure out what the transmission problem was? I am getting the same error message P1728 on my 1995. Got any advice?
Old 03-28-2008, 06:39 PM
What can happen is some metal can get into the electricly controlled valves in the transmission. Best thing to do is change the fluid and filter, perhaps add an inline transmission fluid filter. See if that fixes things. If it still has a problem, something is stuck in the shift valves. Also the torque converter may be falling apart. I just went through this and did the big built transmission with aux cooler and all the aftermarket fixes.
