01 7.3 4r100 issue - Ford Powerstroke Diesel Forum
Old 11-20-2012, 07:00 PM
01 7.3 4r100 issue
I just recently had to replace my cooler lines. I refilled tranny with mercon V fluid then didnt use truck for almost a month, and now l get really hard shifts between 1-2 and 2-3. It was fine before leaving the truck now its bang bang bang.
Old 11-20-2012, 07:12 PM
I see that you have a TS chip, now do you have custom tunes on it or just whatever you got installed with from where you bought it from??
Reason i ask is, TS chips with canned tunes raise your tranny pressures to make them shift firmly and it will be like that til you get some custom tunes installed on that chip. I had the same issue with my TS chip.
Old 11-21-2012, 05:55 AM
Well it was performing fine before I had to replace the cooler lines, that is why I ask. Its bizarre, I never tow and only really use it for home depot runs or when I have to go get something oversized. And it has the programmed TS maps from them. But I get the same result in the stock mode as well. When I replaced the lines it was a warm 70-75 degree day, I didnt run it without any fluid and can't for the life of me figure this out, no one else describes the same thing in any other thread.
Old 11-21-2012, 06:57 AM
Hillbilly Deluxe
Feedback Score: 3 reviews
Take it to a shop and have the trans, lines, and cooler completely flushed. Sounds to me like your accumulator is sticking or you have a line pressure issue.
Sent from my Galaxy S2 while my wife is yelling at me for being on my phone...
Old 11-22-2012, 09:33 AM
Isnt this something I could do myself? I just find it completely odd that this occurs after I drained and refilled it. I drove it yesterday and it seemed smoother, but not like it was before. I read someone saying something about allowing the clutches to acclimate to the new fluid, but that sounded like BS to me.
Old 11-22-2012, 10:58 AM
Was the truck dead when you went to start it? Just thinking that it might be going through a "relearn" period. It might do this as well if it sat for awhile. If it isnt slipping and doesnt feel like it will break anything, I say drive it a few days easily and see what happens.
Old 11-22-2012, 11:22 AM
No it wasn't dead. Brand new batteries and I have it on a solar charger. Do these trsnnys.learn? I never abuse.it cause its expensive for ford parts!
Old 11-22-2012, 11:29 AM
The trans doesnt learn but the PCM that controls the trans does. I wasnt suggesting abusing or that you abuse it. Just telling you to drive it and see if it smooths out unless it is slipping or seems harsh enough to break parts.
Old 11-22-2012, 11:39 AM
No not experiencing slipping or anything violent. Happy thanksgiving!
Old 11-22-2012, 05:14 PM
Hillbilly Deluxe
You wont be able to do a total flush in your driveway... One thing you could check is to make sure you have to correct filter, and that it is pushed up into the VB far enough.
The only way it would be going through a relearn is if you had the batts diconnect long enough to reset the PCM.
