Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 10-24-2007, 06:18 AM
sevenmalards sevenmalards is offline
Here Comes Duck Season!
Need I.D. help for replacement trans.
I'm pretty sure my transmission is toasted. Been having problems with it, and did a fluid and filter change yesterday and man was it UGLY. When I went to the parts house for a filter (luckily I decided to do the dissassembly first) I told the guy I had a '99 2WD, dually, PSD. He came back with the filter and it was the wrong one, COMPLETELY DIFFERENT SHAPE. So he goes and gets another, and its the right shape, but the bottom pick up tube isn't long enough. He says that's the only ones for the 2wd. He goes and gets a 4WD trans filter, I open it and sure enough it's the right one, with the 2 inch pick up tube on the bottom of the filter.
My question is: What is my transmission? Or did someone a long the line put the wrong filter in it? I checked it when I put the pan back up and the pick up tube isn't bottoming out on the pan.
Thanks.
Old 10-24-2007, 10:43 AM
lilredpowerstroke lilredpowerstroke is offline
Ballin' on a budget
Someone along the line probably put the wrong one in. And if the pick up tube was bottomed out on the pan then it wouldn't pick up the fluid would it?
Old 10-24-2007, 12:45 PM
No I wouldn't imagine it would, at least not very much. Is this a 4R100 trans?
Old 10-24-2007, 03:28 PM
Bump. Anybody else???
Old 10-24-2007, 03:39 PM
460+ 460+ is offline
Sounds like it, its possible it also could be E4OD I think.
Old 11-25-2007, 03:09 PM
Transmission Physician Transmission Physician is offline
4R100 units are 98 and up. Some 2wd have the deep pan. If your pan has a hump in the middle then it takes the 4x4 style filter. I rebuild quite a lot of these . If you would like a quote on getting it rebuilt feel free to give me a call . Thanks, Chad 352-455-5543
eBay Motors: ZF S650 6 SPEED FORD F350 F450 F550 TRANSMISSION (item 260185493728 end time Dec-02-07 05:51:07 PST)
Old 11-25-2007, 09:09 PM
Yeah...Thanks anyway but being in CA where JOHN WOOD TRANSMISSION is, I wouldn't ship it to FLORIDA!
That would be totally
Old 11-25-2007, 09:28 PM
Dirk Dirk is online now
Local 7.3 Techie Panda
4r100. I'm willing to bet there was a problem at the parts store.
Old 11-26-2007, 06:31 AM
LUCILLY I dropped the pan first to get a look at the filter, and sure enough when I went in they tried to give me the right, but wrong one!
"this is what it calls for" BUT THAT'S NOT WHAT IT LOOKS LIKE! So the GUMBY opened a box with a 4X4 filter in it...THAT'S THE ONE! "But it's for a 4X4!
I don't care if it's for a go cart, that's the one now give it to me!
Old 11-26-2007, 07:47 AM
Now I want a powerstroke go kart.
Thanks a lot!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
