Friend Stuck In Ohio - '06 F250 6.0 - Ford Powerstroke Diesel Forum
Old 01-16-2012, 04:20 PM
Exclamation Friend Stuck In Ohio - '06 F250 6.0
My Friend is on the way back to NY from WA. He just got out of the Army.
He was on the Highway and all the sudden his Truck went into Limp Home Mode and Tow / Haul Light is Flashing.
He Pulled the Codes and they are: P0700 / P1000 / P0748 / P0960 / P0962
He Looked them up as best as he could and got as much info as he could, and got a New Line Pressure Control Solenoid and Trans Temp Sensor. He said that's what Looked like was causing the Problem.
He Installed them, Cleared the Codes and they came right back as soon as he Started the Truck.
When he Dropped the Pan, he said the Fluid was still nice and Red, didn't Smell Burned, and no Metal Shavings in Pan either. He Checked all Electrical Connectors everywhere he could, and Looked for Harness Rub-Through or Cuts and didn't find anything.
Does anyone else have any ideas as to what could be Causing the Problem? He's been Stuck there since early Saturday Morning.
He got Tired of Sitting there, so put everything back together, and he's just gonna Limp it Home here to NY as Fast as he can.
