1990 e4od problems need help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-25-2011, 09:28 AM Thread Starter
I have a 1990 E350 with a 7.3 and e4od. I was driving up the road about an hour ago when I suddenly lost power. I coasted to a stop, opened the hood and realized I had battery cables loose. I reconected them and tightened them. The van started right back up. When i put it in drive and went to pull out it felt like the tranny is in 3rd gear. When I pull it into second and first it downshifts but both 2nd and 1st position feel like the same gear. So I think I only have 2 gears 2nd and third and it will only shift manually. What should I start checking?
suckfumes1984 is offline
post #2 of 2 Old 07-03-2011, 10:35 AM
Did you find out whats wrong?
I have a IDI with a e40d as well. Would be good to know what you found.
Sorry I'm not posting some useful info for you.
7river is offline
