Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 05-29-2006, 01:27 PM
aldo_45030 aldo_45030 is offline
OD light flashing fluid dripping from
flywheel cover.............. crap really making me wish i had bought a duramax already. PUlling 5th wheel got off high way and took it out of od since it would be stop & go. stopped at the inlaws for apprx 1 hr no more flash. Temp of tranny never left "normal range did get slightly high hat 1 point till i shifted into od in a flat area then dropped. Tranny was replaced by ford @ 25K mile now showing 50K. what is fords warranty? it is a e40d?
Old 05-29-2006, 05:20 PM
Worm Drowner Worm Drowner is offline
Take it back to Ford immediately! You don't say what year truck it is, but if it only has 50k on it, I doubt it is an E4OD. If they have already "fixed" your tranny once and it is still FUBAR, I would suggest reading the service manager the riot act if he even so much as thinks about giving you a hard time. I have an E4OD in mine with 125K miles and it runs like a top. There is no excuse for two failures withing 50k miles.
Old 05-29-2006, 06:22 PM
Sorry it is an 2003 7.3 according to the former owner who took very good care of the truck. He said it was a completely new tranny not rebuilt.
Old 05-29-2006, 06:59 PM
mschn99 mschn99 is offline
the front pump seal is out of it....and unfortunately if it was a ford trans that was put in it, then could not have been new....the only way you can buy one is a reman. that trans carries a 3/36 warranty, so take it back and tell them to make it right......Marc
Old 05-29-2006, 07:08 PM
Crap.... the story i got was it was new from the transmission plant in sharonville oh were i grew up ......... figures i know 2 people that worked or i should say collected a paycheck from there and both were not to swift.
Old 05-31-2006, 06:46 PM
OK tranmission gurus here are the code from my tranny problem.
P0603 internal ctrl kam error
p0783 3-4 shift error
So what does this mean?
Replace or rebuild?
Old 06-02-2006, 03:41 PM
the P0603 is from your chip and is normal
the other code means you probably had the 3-4 clutches slip. thats what caused the overheating. if it was me i would take it to a good trans shop and have it rebuilt if they determine thats nessicary, and if they do, i would have it beefed up a bit......Marc
Old 06-02-2006, 03:45 PM
super_stroke super_stroke is offline
Power Strokeaholic
hey marc, will it throw a code if it sense a slip?
Old 06-02-2006, 03:56 PM
it will throw a code if the slip involves a line pressure change i beleave.......
Old 06-03-2006, 06:17 AM
As the tranny turns continues........
ok the dealer called and said it would be $650 to take it out and apart to determine the problem...So is said isn't that covered by the remanf trans warrenty??? no it was a rebuild not a replacement out of luck. You mean i have to have my tranny rebuilt every 25K .... no you shouldn't ......well you rebuilt WTF? Long story short i will purchase a powertrain warrenty for 500 and it will cover the trans and anything else 6 yrs 75K miles. SWEET i wanted some coverage anyway. The fellows at Kings Ford in cincinnati worked with me so far and i appreciate it......beats the snot out of 3K for another rebuild.
