Slave cylinder fail! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-05-2011, 10:20 PM Thread Starter
nccatfan's Avatar
Send a message via AIM to nccatfan
So I was on my way to work today, then with about a mile to go, as I shift into 3rd my clutch pedal drops to the floor! After a quick bit of panicing, I end up floating the gears the rest of the way into work. After a few minutes of diagnosing, I found the line loose at the back of the slave cylinder. I had replaced this entire assembly (the pre-bled kit from Ford) back in Feb. And that was after I had replaced my clutch with a new OE grade Valair clutch.
My question is; these stock hydraulic components are supposed to be able to handle aftermarket clutches, right? Did I just get a defective part? It only lasted 4 months!
-'99 F250 7.3L PSD 4x4 (SCLB, 6-speed)
-'14 F150 4x4 5.0 CCSB
-'83 Ranger 4X4 5.0
nccatfan is offline
post #2 of 5 Old 05-05-2011, 10:40 PM
spool up that turbo!!
hollister25073's Avatar
The pre bled kits are hit and miss I've had the tabs of the slave cylinder actually snap and fell out of the bellhousing and have ha the line leak the local shop replaced mine for free
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
boost pyro and engine oil temp
AIH delete, hpx, frx
05 harleys 8000k's
billet grille and painted shell
17"welds and 35-12.5's toyo mt's
cab lights
southbend con ofe waiting to go in
fresh 7.3 from reviva
SOLD
1995 f150 302 5spd 35's sad sad day
hollister25073 is offline
post #3 of 5 Old 05-05-2011, 10:45 PM Thread Starter
nccatfan's Avatar
Is there an upgrade for this? If the next one fails I'd like to go to something more reliable.
-'83 Ranger 4X4 5.0
nccatfan is offline
post #4 of 5 Old 05-05-2011, 11:14 PM
at0075's Avatar
I just replaced master and slave cylinder on mine. I would think a stock slave would be fine. Correct me if I'm wrong someone . The pre bled kit from Ford is a rip off. I took the whole system off and put the new parts on the stock line and had it bled and back on in 30,minutes with no problems. Also the factory slave is plastic , well least on mine it was and I replaced it with a metal heavy duty slave. Maybe try that
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #5 of 5 Old 05-05-2011, 11:18 PM
at0075's Avatar
forgot to mention also replaced master with heavy duty metal. I think I got these at advance auto
at0075 is offline
