7.3L IDI - E4OD hard shifting issues?????
93 F-350 7.3L non turbo IDI, E40D tranny. Truck shifts hard in every gear including od. Did a little adjustment with the sensor on the sidr of the IP, this helped a little but still shifting hard.
How much can I adjust this without messing something else up or is there some way to make these adjustments with a scanner? OD light works fine, no flashing od light, speed-o and tach all work just fine and no abs light on either. |
STILL NEED HELP!
Got the adjustments made to the tps and set to factory specs.... Trans still shifting hard. But did notice with the truck cold and the high idle on this thing goes into gear smooth and shifts just perfect until it get warmed up then starts the hard ****fing crap.
We have had 2 different scanners hooked up and this truck has ZERO code found! Pulled the pan and no shift kit found fluid smells great and color was good too. Looks like someone has installed a new silonoid pack not to long ago. WHAT CAN I DO? Been at another tranny shop since Friday with no luck so far. |
