- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
4R100 Transmission Slipping
My husband is having a problem with his truck, so I was searching some sites on the web and found you guys. Your site looks awesome and I've seen some helpful info already so I thought I would sign my husband up and then ask some questions! Here's the deal (BTW - 2002 Ford F350 Diesel) - Truck runs fine cold, once its warmed up trans starts slipping between 2 and 3 and then gets stuck in 3rd and won't go in reverse. My husband and my brother did something (not sure what) but the reports were "no metal shavings in the fluid" "fluid low, but nice and pink not burned". We've got this computer thing that they hooked it up to and they said "it didn't throw any codes, so it's not electrical". My concern is that the boys (hubby and bro) want to buy about $800 in parts that they aren't sure whether or not they'll fix the problem. They've been talking about a Clutch Assembly Pack - I believe or maybe clutch valve assembly, and they were saying something about a cylinoid but I think thats been abandoned after the "no code" thing. These trucks are expensive enough to own and maintain, I want to get it fixed for sure and I want it done right but I dont want to spend any more money than necessary. Any suggestions??? Thanks!
| Sponsored Links |
not a tech by any defination, but from what I've learned here, unless the code reader is specifically for transmissions, it won't pick up on any codes that may be registering. I know that at some point, (probably when I can least afford it) I'll have to have mine replaced. (I've got an 03 E550..a bit bigger and heavier than your's). Depending on the severity of the duty your truck/tranny is used on a consistant basis, you might be better off having one built by BTS or Suncoast. From everything I've heard, they're practically distruction-proof. However, I'm certian that those more knowledgable in trannys and such will chime in pretty quick to give you some guidence.
is the truck stock? or has he done any mods on it? how many miles on the truck too.... mine went out a couple of months ago but that was because i have been moding my engine and the stock tranny coudlnt handle it anymore....a valve body will improve the shifting and feel of the truck but not sure if that is why it gets stuck in 3rd and wont go into reverse......slippage is usually caused by a bad or worn torque converter so an upgrader TQ would help dramatically.... im sure a tech will be along shorty to get your better info..... oh BTW welcome to the Org. -Raul |
Now to the orignal Poster bigjerm welcome to the org. Now for the trans problem, when the fluid is cold it is thick there for not allowing the trans to slip. When the fluid gets warm and thins out and then the trans starts to slip. Now I am no expert but I am on trans number 4 with my 2002 F-250 4x4. What I learned is this, your syptoms are calling for a rebuild of the trans. Most likely the clutches for the trans are pretty much done and need replaced. I suggest a complete rebuilds with upgrades. If you have a shop do it plan on spending around 2500-2700 dollars to repair the problem. |
| Sponsored Links |
