Torque converter plug? - Ford Powerstroke Diesel Forum
Old 08-21-2010, 07:39 AM
Doing a fluid / filter change today. Took the inspection plate off expecting to see a 1/4 inch drain plug on the converter. Not there? Am I mistaken thinking it should be visible from there? thanks twodot.
Old 08-21-2010, 07:44 AM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
well,what kinda year ya got there??? i dont think there is a plug on the tc.i took mine all the way off and didnt see a plug,course i was not paying attention.i was rebuilding my motor
Old 08-21-2010, 07:49 AM
harley, it is a 97, F350, four wheel drive. I also can't find a drain on this tc. Is there any other way to get all or more of the fluid out? thanks
Old 08-21-2010, 08:05 AM
ohh yae there is a way,drop the tranny and pull the tc...you wont get all of it out if you dont pull the tc.well i think there is a way,you have two lines on the passenger side that go to the coolers..well one line goes to the radiator and one to the external cooler,disconnect the two lines from the tranny and start the truck.holdin a bucket under there of course.i think that is the only way.
Old 08-21-2010, 11:42 AM
Got it!! Drained pan, replaced filter. Put pan back on and poured in 8 quarts fluid. Removed rear tran. fluid line. Started and ran truck while catching fluid from rear line in bucket. Caught about 6 quarts. Put line back into trany. Filled up until stick said full. OD light was still flashing. Pulled positive cable from each battery. Hooked back up and started, no light flashing!! Went for good drive up and down hills. Runs like a champ!! Thank everyone for their input here. twodot.
