tranny help please! - Ford Powerstroke Diesel Forum
Old 06-19-2010, 04:50 AM
tranny help please!
my 05 torque shift was leaking from the pan gasket towards the rear so i replaced it and it seemed to leak from the passenger side thinking i over torqued the gasket I took it off and used "the right stuff" and it is still blowing fluid and I think it is only in reverse when this happens I cant seem to see if there is a hole or not in the body but watching it leak and there is no fluid coming from a higher point leads me to believe that it is the gasket is there something I am missing a sequence or torque specs that are important your knowledge is greatly apreceated. thanks
