so i just got done installing a Factorytech VB and a PI stalion TC put the proper amount of fluids in even aded an extra 40k cooler and inline filter.
i did the front pump mods required for the TC. so i went for a test drive and 1-2 shifted perfect, 2-3 banged into gear real hard then after that i wouldnt go into 3 under acceleration, so i let off the trhottle and it would immediately shift into 3rd but back on the throttle it will go back into 2nd what is wrong with my truck. i need it to be fixed by the end of the week. is it something that i did that screwed up my tranny or is it just toast. please help i already dumped a ton of money ionto the tranny and really dont want to have to have it rebuilt ![]() ![]()
oh and the temps got to 190* real quick normally i barely reach 160*
well just checked all connections everything on the outside looks good. went for a test drive again same thing i mentioned above and now no reverse until you give some trhottle then it slams into reverse.
ok got the fluid levels perfect. it shifts 1-2 fine the the TC locks up then 2-3 is real hard then 4/od is normal. sometimes the 2-3 shift is normal but then i have no reverse, after i get reverse to engage it shifts hard 2-3 and wont go into 4th. any ideas would be greatly appreciated
thanks Jordan |
It could be an issue with the valve body......
Dayum Man I am sorry to hear about your issues, but if the trans all worked fine before the upgrades I would say it is something to do with that. I personally would give BTS a call and tell tham the symtoms and maybe they could help.
Re-reading this thread makes me think it isnt locking/unlocking the tc like it should... It would explain the need for revs to get into reverse and the hard 3rd shift....
