Reverse is gone - Ford Powerstroke Diesel Forum
Old 04-14-2010, 11:05 PM
Reverse is gone
when i put it in reverse i have to give it gas and the whole truck shakes. 2005 f350 drw 6.0. I bought the truck last Aug, and the warranty on the powertrain is voided due to the previous owner / idiot.
Old 04-14-2010, 11:52 PM
'Merica
Check fluid levels. Any programmers installed? My old Edge tuner had a lunch buffet on my transmission, and i ended up with the same symptoms (shaking in R, having to give it gas to move) before it finally gave up the ghost.
Also, i had a Tran. cooler line with a pinhole, and the two situations coincided to me building my trans right.
Edit: there was also a TSB on reverse snaprings, but it does not apply to your truck IIRC
Old 04-15-2010, 09:23 PM
My fluid levels are fine. SInce i have owned it i havent put any mods on it. But Im assuming the previous owner might have which resulted in the warranty being voided
Old 04-22-2010, 11:32 PM
well everything is getting worse, i dont know what to do
Old 04-30-2010, 12:08 PM
got the same problem bud. is it running real high rpm in like 2nd and 3rd gear now too? ima watch this one and give ya a bump.
Old 05-02-2010, 12:09 PM
yea its shifting really hard now.
Old 05-03-2010, 09:35 AM
ive added a quart of gear oil from a tractor, its a lot thicker than trans fluid...that and 2 quarts of trans fluid and its doing better. trucks at home but im waiting to get home to decide to dump more trans fluid in or to drop the pan check the filters and the fluid itself and do a flush.
