Hi all - newbie to the forum and already I have a recent problem that cropped up.
This is the issue with the dreaded transmission OD light causing hard shifts, etc. I've read thru the forums and found some tidbits of info; however if anyone out there has experience and can pass along their knowledge it would be highly appreciated The truck: - 1994 F250 4X4 longbed, super duty, extended cab, IDI Banks Turbo "K" engine, Automatic OD transmission The symptoms: - Transmission works fine when first starting in the morning - shifts smoothly and all is good. Within anywhere from 30 seconds to 3 minutes, the system goes into "O/D flash" mode (a limp mode as I understand it) and the 1-2 and 2-3 shifts 'bang' into gear. The questions: - Apparently there are trouble codes stored - can these be accessed via the standard OBD port - or is there a separate port available & scanner needed for tranny problems? - From what I have read - I should start with a trans fluid flush to start - the fluid is a little cooked already so it can't hurt - Is there a FAQ on this issue somewhere? Any and all knowledge is appreciated in advance Thanks! Last edited by nixter; 01-20-2010 at 03:31 PM. Reason: Adding aftermarket turbo info |
Well I think I found it - and I am posting for any others who may have this problem.
After some forum surfing I found that the tach sensor can be the culprit. As a test, I observed when the OD light would start its flash routine and saw that is was when I was in the mode of slowing to a stop. The tachometer reads zero revs at idle and the connection to the tranny issue did not click until just now. I am guessing that as the truck rolled to a stop and I took my foot off the throttle, the speed sensor (rear axle?) read forward speed but the tach showed zero - this must have freaked out the automatic trans computer and set the O/D light error. I bumped the idle so the tach would read something and took it for a second drive - problem did not crop up. Ordered the sensor at the local Ford dealership for about a hundred bucks. Not a bad bad price overall... Keep on truckin' |
"not a bad price",, unless you know they used to be $39.
Glad you got it fixed, I had the same problem few years ago when I changed the fuel bowl on it and dumped 1/2 gallon of diesel fuel down the back of the motor and fired it
![]() Was neat tho cause when you'd floor it, it will chirp gears through all 4
