HELP! 6.0 Tranny going or what? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-25-2009, 11:58 PM Thread Starter
T.R.P.'s Avatar
Well today my truck started making this whining noise. The sound is in harmony with the engine and the rpm's. I set the truck back to stock and it slipped twice and then slammed into 3rd gear but the whining was much quieter.
Also, it whines when it is in park and neutral and you give it some fuel. My tow/haul button started blinking too!
Truck has 36,000 miles on her. Why is my tranny going?
Come on guys. PLEASE!
If you don't drink Dos XX's, you need to start today.
2007 F-250 Lariat FX4
SCT w/ Matt's SRL
37" Toyos on 18's
75,000 HARD miles and absolutely no problems. What's the deal Bill?
T.R.P. is offline
post #2 of 4 Old 11-26-2009, 01:48 PM Thread Starter
T.R.P.'s Avatar
Unlocked the hubs and it doesnt wind nearly as much and does not slip. Also, the fluid has never been replaced and is extremely low. Could it be bad fluid doing this?
I am thinking about dropping the pan and checking the internal filter for metal flakes or shavings. What do ya'll think?
SCT w/ Matt's SRL
37" Toyos on 18's
T.R.P. is offline
post #3 of 4 Old 11-26-2009, 03:37 PM Thread Starter
T.R.P.'s Avatar
Just drove it and it FINALLY threw a code.
PO741
Torque Converter Clutch Solenoid ckt perf./stuck off
Do I need a new torque converter?
SCT w/ Matt's SRL
37" Toyos on 18's
T.R.P. is offline
post #4 of 4 Old 11-26-2009, 04:05 PM
JER-1's Avatar
Quoted: 17 Post(s)
Cool
I don't know. But if it were me and tranny fluid was really low I beleive I'd go ahead and do a complete tranny flush and new filters their are 2 in my 2005 f-350,and see what happens. I also would not drive until I'd did the flush. Or you might just fill tranny to full level and see if that stops the whinning.I guess the first way if it goesn't fix it you would be out 16 or 17 quarts of fluid and 2 new filters,and the second way just a couple of quarts.I'd do the whold thing though if that doesn;t help it then your out 100.00 bucks. Like I said I don't know just what I'd try first personally.
Maybe one of these brighter fellows will come up with a good answer.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
