Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 10-25-2009, 09:51 AM
89MustangGX 89MustangGX is offline
Internal Trans Filter Help
Just changed the internal trans filter in my 06, replaced with one from an 08 for better filtering. (Also replaced pan with one from an 08, bigger filter needs bigger pan).
The filter sort of snaps up into the tranny with the orange rubber o-rings holding it up tight inside. BUT, the filter can still swing back and forth a little if you push it and seems to be a little wobbly at the very end of the "L" if that makes any sense. I can't see how it would go in any tighter or sit up higher -- it seems to be in all the way. I even pulled it back out and it is definitely in tight (took same effort as original filter to pull out), and when put back in it is exactly the same.
Is this normal?
Adam
Old 10-26-2009, 03:47 PM
ttt.......
Old 10-26-2009, 06:15 PM
95dieselsmoke 95dieselsmoke is offline
keep yer eye on the prize
Did you make sure the old orange oring came out with the old filter? They usually get stuck up in there when the old filter is removed.
Old 10-26-2009, 07:09 PM
Yes -- the orange o-ring was stuck up in there and I pulled it out with a little pick before putting the other filter in. It fits in tight just rocks a little at the bottom and can be turned side to side. But like I said, I pulled it out to see how tight it was and it is in tight, just like the original.
Adam
Old 10-27-2009, 04:20 PM
TTT
Anyone change an 08 style internal filter and remember how tight it fit?
Adam
