Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 02-16-2007, 04:02 PM
Sportsnutim Sportsnutim is offline
A/T going belly up....
Well...my transmission finally couldn't take my 2001 4x4 diesel torque anymore it won't drive or go anywhere in "D" but second works, first and reverse. Does anyone know of a reputable a transmission or performance transmission company online?
Old 02-16-2007, 04:04 PM
Big Tone Big Tone is offline
Suncoast is the name that keeps poping up
Old 02-17-2007, 01:29 AM
stroker27 stroker27 is offline
if it doesn't go anywhere in "D" but it does fine in second it might not be bad..... 'cuz it obviously doesn't start out in 4th gear'. did you check your shift cable adjustment? it is on the drivers side of your trans i believe and there is a square white plastic thing holding your cable to your tranny i would check that before u go buyin a new tranny. unless your looking for an excuse to upgrade anyway. theres also a possibility that something came off or is loose in your steering column
Old 02-17-2007, 03:15 AM
straycat straycat is offline
Moderator
Good advice stroker, definitely check it out before you pull the trigger.
Old 03-19-2007, 09:33 AM
dkmunns dkmunns is offline
if you have 1,2, and R. chances are its the spragg gear.
Old 03-22-2007, 02:29 PM
ipz2222 ipz2222 is offline
dkmunns, there are 3 spraggs in the trans. Which one are you refereing to?
Preston
Old 03-23-2007, 04:56 AM
The Forward Spragg For The Drive Clutch Pack.
Old 03-23-2007, 09:09 AM
quick26 quick26 is offline
i am sorry, this is off topic, but stroker27, bigger is not always better, did your wife get mad about you stealing the trash can out of the kitchen
Old 03-23-2007, 10:35 AM
JUGGERNAUT JUGGERNAUT is offline
Drain your fluid if it has alot of clutch material in it the accumulater body could be clogged and sticking. I had a hell of a time getting 2 of the 3 cups out.
Old 03-23-2007, 04:46 PM
WV Hillbilly 97 superduty WV Hillbilly 97 superduty is offline
I had an E40D go bad 4 years ago and the shop I went to said I had 3 choices. A rebuild thru him $1,800.00 w/ 1 year waranty at his shop.
Option 2 a new Ford factory trans for $2,100.00 with 1 year warrantee.
or the 3rd option and the one I chose-a Jasper trans with a nationwide warrantee w/ 3 years or 75K miles for $2,300.
Here is why I chose option 3-Warranty-nationwide warranty-and at 2 years 11 months and 19 days it blew a front seal and Jasper decided to replace the trans at no cost or deductible... Warranty!!!!!
PS You can contact Jasper on line and locate a dealer.
