Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
  #11 (permalink)
Old 08-02-2009, 08:18 PM
Dave Dave is offline
Obama sucks
I dont think that getting a bigger will do that much as the cooler you already have should be the best out there!
I dont see an aftermarket cooler listed and its a 7.3 Ryan
  #12 (permalink)
Old 08-02-2009, 08:26 PM
RRonning1984 RRonning1984 is offline
Heavy Equipment 911
I just looked at the sig pic.
  #13 (permalink)
Old 08-02-2009, 08:28 PM
97 golden stroker 97 golden stroker is offline
If the thing started getting hot overnight it sounds like a problem more the the cool, many being pluged but not being too small. Seen on of these trucks like a moth ago same problem and the kept driveing and fried the tranny when the only problem if first place was the tc.
  #14 (permalink)
Old 08-03-2009, 11:55 AM
strokinnsmokin strokinnsmokin is offline
Well I caAlled the tranny guy today he said he is almost sure it isnt the TC due to the codes it threw an the way it still runs good but did tell me to replace the check valve on the back of the tranny I tried calling the dealer toget a price but they dont know what that part is that im talking of can anyone help out?
  #15 (permalink)
Old 08-09-2009, 03:39 PM
so I replaced this on sat an still running hot any other ideas? also w/ the old fluid would that have something to do w/ it running hot still?
  #16 (permalink)
Old 08-09-2009, 04:12 PM
BIGBILL105 45 BIGBILL105 45 is offline
I would drop the pan and change your fluid and transmission filter. Too hot of temps could break down the oil and cause it not to dissipate heat as well.
  #17 (permalink)
Old 08-19-2009, 12:16 PM
Changed the filter/fluid an installed a 6.0L trans cooler an still running 190-210ish any other ideas on whats goin on?
  #18 (permalink)
Old 08-19-2009, 12:27 PM
Black&Gold Black&Gold is offline
pull the pan and pull the valve body's and check that all of your valves are moving freely, if they are sticky and one completely sticks then you will end up with one burnt transmision. best to check now to prevent a whole trans. rebuild. while you are in there it wouldnt hurt to throw in a shift kit.
  #19 (permalink)
Old 09-05-2009, 09:45 PM
gabe74gt gabe74gt is offline
I am also feeling the same thing.
  #20 (permalink)
Old 09-06-2009, 10:32 AM
I dont knew if i would trust that tranny shop that you are working with that told you its not the tc. but if you call a good tranny shop they will tell you that it could very well be the tc. you should try to find a good tranny shop to test it for you.
