Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Tranny 911
Old 02-12-2007, 10:33 AM
stroker27 stroker27 is offline
torque converter
i just got a new torque converter by UPS. i was checking it out and noticed that the gear i could see inside there was not centered. so i tried to move it around and it moved around! is it supposed to do that? it turns just fine with no noise but it moves up down and side to side just dont know if thats normal. it is not full of fluid
Old 02-12-2007, 11:18 AM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
I have never noticed anything like you are explaining. I would contact the place you got the TC from and see what they say.
Old 02-12-2007, 04:06 PM
NOVAJOE105 NOVAJOE105 is offline
What You Are Seeing In There Is The Turbine In The Convertor. I Will Move Around Some. Make Sure That When You Put The Convertor On The Trans, I Seats All Of The Way In. You Should Hear Three Distinct Clunks And The Convertor Will Move In At The Same Time. To Do This, Start The Convertor On The Input Shaft. Hold The Pilot Snout In The Center Of The Convertor In One Hand And Use The Other Hand To Rotate The Convertor Back And Forth While Pushing In On The Center Pilot. You Can Turn It As Much As You Want Each Way. I Usually Go 1/2 To 3/4 Turn Each Way. When It Is Seated, You Should Not Bea Able To Get Your Fingers In Behind The Convertor Between It And The Trans Case. If You Have Any Questions On This. Please Feel Free To Hollar At Me And I Will Help The Best I Can
Old 02-13-2007, 05:01 AM
thank you! now just one more for this one. how full do i fill the tc before putting it on, do u know how many quarts it'll take?
Old 02-13-2007, 05:59 AM
I fill the tc up until the tc bowl is full. I call the bowl where all the clutches and discs and fins are. Check the paper work that came with the tc. That should tell you how many quarts the tc holds. I would think 3 or 4 quarts. Thats how many I put in the tc's I have installed before and haven't had problems from not having enough fluid.
Old 02-13-2007, 06:53 AM
it is a rebuild, comes with no paperwork, maybe the paperwork will come with the tranny the tc got here first
Old 02-13-2007, 06:50 PM
I AGREE WITH BIGC. PUT AT LEAST TWO QUARTS OF FLUID IN THE CONVERTOR BEFORE YOU PUT I ON. MAKE SURE YOU INSTALL A NEW TORQUE CONVERTOR SEAL AND LUBE THE SNOUT OF THE CONVERTOR BEFORE YOU INSTALL IT. YOU CAN USE TRANS FLUID OR SOME LIGHT GREASE ON THE CONVERTOR SNOUT. I ALWAYS USE SOME PERMATEX #1 SEALER ON THE OUTSIDE OF THE SEAL BEFORE DRIVING IT INTO THE PUMP. GOOD LUCK. HOPE THIS ALL HELPS.
Old 02-15-2007, 04:29 AM
hey thanks! im not sure if the new one came with a new seal or not i dont wanna get everything together and have a leak! maybe can you tell me what im looking for?
Old 02-15-2007, 04:53 AM
My rule of thumb being the seal costs 2 bucks. Replace it anyways, it is only 2 bucks for that cost you know that you have a new seal in it. Also you know that seal is installed correctly. The seal we are talking about is the Front Input seal on the tranny that seals the torque converter with the tranny pump.
Old 02-15-2007, 07:22 AM
so its located ON the transmission and not the TC
