Tune or No Tune? - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
Old 06-20-2009, 11:47 AM
Tune or No Tune?
Are u guys running tunes when hauling a heavy load and if what tune are u using? Im hauling a 8.5 ft lance truck camper and towing a 19ft custom weld aluminum boat. The camper weighs in at about 2000lbs all load up and the boat around 3700lbs. Am just curious. Thks
Old 06-20-2009, 11:58 AM
Im a 7.3 guy but yeah the 6.0 trucks and pulling fine with a tune, just keep an eye on your egts and you will be fine. What tune are you thinking? Also your pulling/hauling very light loads so I say no concern.
Old 06-20-2009, 11:59 AM
wriott
Guest
Posts: n/a
you can haul with what ever tune you want just keep an eye on the EGTs
Old 06-20-2009, 12:03 PM
i use to tow a 10k pd toy hauler with dj's looney tune. just gotta watch the egt's
Old 06-20-2009, 01:29 PM
ya i def keep an eye on the egt's! i only have the preloaded tunes and have used the tow/haul tune but fuel mileage blew. getting better mpg's running stock.
Old 06-20-2009, 01:31 PM
most people get the best mpg using the higher setting tunes. get custom tunes. you wont regret it
Old 06-20-2009, 01:32 PM
is there anyone u would recommend for a good tow tune. i dont have head studs so dont want nothing too extreme.
Old 06-20-2009, 01:33 PM
say no to rolling coal
Watching your EGT's is fine, but they really don't mean much compared to the one thing that you CANNOT see when towing with a performance file. You can't see cylinder pressures, and believe me with extra fuel and advanced timing of the higher HP files your pressures will be up there. My advise is to tow stock or with a tow tune only. The loads you posted aren't much at all and in your case I wouldn't worry too much about running a tow file, maybe even a mild street file. But the safest bet if your heads aren't studded or your EGR deleted or blocked is to tow stock.
Old 06-20-2009, 01:36 PM
thks. ya thats exactly what i was thinking and worried about while i was towing using a tune. i only have about 30k on the truck so am waiting to get the head studs and egr deleted
Old 07-31-2009, 02:49 AM
Originally Posted by shane23451 View Post
In Australia and New Zealand, the popular Ford Falcon has long been considered the average family car and is considerably larger than the Mondeo, Ford's largest car sold in Europe. Between 1960 and 1972, the Falcon was based on a U.S. madel of the same name, but since then has been entirely designed and manufactured in Australia, occasionlly being manufactured in New Zealand. Like its General Motors rival, the Holden Commodore, the Falcon utilizes a rear wheel drive layout. High performance variants of the Falcon running locally-built engines produce up to 362 hp (270 kW). A ute (short for "utility," known in the US as pickup truck) version is also available with the same range of drivetrains. In addition, Ford Australia sells highly-tuned limited production Falcon sedans and utes through its performance car division, Ford Performance Vehicles.
Maserati Dallas Texas
Dish Network Promotions
