haulin a shed - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
Old 05-25-2009, 08:25 AM
duct tape & zip ties
haulin a shed
Ok I am going to pick up a shed 8ft wide 12ft long. I have my trailer it is 84 inches wide and 16 ft long. I know it the shed will over hang a bit. I am not worried about that.
But here is what I am trying to figure out. How to get the shed onto the trailer.
My idea is jack up the shed and place on jack stands. That would make it high enough to back the trailer up under neath the shed. Then lower it back down once the trailer is under neath the shed.
I know it would be nice to have a tractor with forks. But I don't have one, and I can't get one by 3pm today.
So do you all think my idea of jacking up the trailer is good enough.
Old 05-25-2009, 08:30 AM
Go get your self four hi lift farm jacks. Put one at each corner. I have seen this work!
Old 05-25-2009, 08:34 AM
Dang you know what I am gonna have to swing by my dads now. Because I think he has one of these laying around. Then my buddy has another I think at his house. I can lift one end at a time. Place them on jackstands then lift the other end and place on jackstands.
Old 05-25-2009, 10:04 AM
mid day bump, any other ideas. I have till 3pm to have this figured out.
Old 05-25-2009, 10:24 AM
Sounds like you already know my best idea, jackstands. Sounds like this project could make one heck of a redneck camper.
Old 05-25-2009, 10:34 AM
wriott
Guest
Posts: n/a
heck if i would have known about this earlier i would have brought my skidsteer with forks down and could have done it. but the jacks will work as long as your trailer can fit between them.
Old 05-25-2009, 10:40 AM
Send a message via AIM to ford_trck
I would go with the jacks and some wood cribbing or something to block it up as you back the trailer under it.
Old 05-25-2009, 11:31 AM
You got some good jack stands?
Old 05-25-2009, 11:34 AM
Could you use a cable puller/cum-a-long to pull it on? Thats how I got a shed onto my trailer. I sat the shed on small pieces of pvc pipe and it sort of rolled on it.
Old 05-25-2009, 11:59 AM
You could also use boards to skid it along. And apparently dish soap on the boards will help a bunch as a lube.
But if the trailer 8 ft wide just block up the shed on the sides and back right under it.
