Air pressure/towing - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 10 Old 08-09-2014, 02:52 PM Thread Starter
08forddr's Avatar
Air pressure/towing
What air pressure is everyone running while towing. I have 35 12.5 X 20 mud tires and towing 11000lbs. I got 18000 miles out of my last tire before breaking 2 belts. Not sure if it was pressure or just cheap tires. I was running 60psi. Thanks for any help.
2008 CC Lariat short bed
35x12.5x20 XD Hoss , Leveled
Sct tuned by IDP , Air bags
08forddr is offline
post #2 of 10 Old 08-09-2014, 03:00 PM
Quoted: 28 Post(s)
They're E load rating correct? I run 75 rear 65 front all the time.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #3 of 10 Old 08-09-2014, 04:05 PM
Vannnce's Avatar
Quoted: 13 Post(s)
i run the max cold psi thats on the tire. since its hot here in south texas, i check/inflate them in the morning when its coolest
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #4 of 10 Old 08-09-2014, 05:47 PM Thread Starter
08forddr's Avatar
Yes E rated. It seem everything I can find is what your running. Thanks everyone.
08forddr is offline
post #5 of 10 Old 08-17-2014, 04:50 PM
Quoted: 6 Post(s)
I run 70 psi all the way around.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #6 of 10 Old 03-28-2015, 07:08 AM
SOLOLUCKY's Avatar
Quoted: 17 Post(s)
When towing I run max cold pressure all around as well.
And on the trailer as well...max'em out
SOLOLUCKY is offline
post #7 of 10 Old 03-28-2015, 07:34 AM
ZMANN's Avatar
Quoted: 1673 Post(s)
Max cold psi for Me also
if not loaded/towing I revert back to the PSI i found using the
chalk test http://www.nitrogentiremachine.com/p..._inflation.htm
We Miss you Ronnie
ZMANN is offline
post #8 of 10 Old 05-17-2015, 06:23 PM
SOLOLUCKY's Avatar
Quoted: 17 Post(s)
max llisted on tires for me when loaded...will drop'em down maybe 5 psi when unloaded on the truck...but trailer is always full cold PSI listed on tires...always maxem out.
SoloLucky, I love my diesel but it ain't for a poor man to own!
2004 CCLB, XLT, 6.0, auto, 4" MBRP full exhaust, 4" lift
1999 eXcAB, XLT, 5.4, auto, stacked, SCT tuner, 4" lift, fully modified as far as I can take it.
post #9 of 10 Old 05-21-2015, 06:16 AM
This. Max pressure, esp on trailer tires. Heat and flex kill tires, both are worse with less pressure.
96 F350 CCLB SRW, tymar intake, 4 in turbo back exhaust, banks intercooler, beans 6 pos chip, bronco 37 gal rear tank. Tows horses around KY.
KYpatriot is offline
post #10 of 10 Old 08-07-2015, 11:43 AM
SOLOLUCKY's Avatar
Quoted: 17 Post(s)
that "chalk test" is prety cool ....i will be doiing that soon...determine the optimal "empty pressure for the truck.
