6.0L towing 5K question - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
 3Likes
  • 2 Post By Airborne CIB
  • 1 Post By Teachagmech
post #1 of 8 Old 06-18-2014, 11:52 AM Thread Starter
RY86's Avatar
Hello, I just bought an enclosed 28x8 car hauler that my dad an I plan to use for are ATV trips or during moose hunting season. My total trailer isn't extremely heavy at 4995lbs loaded. I had wanted to ask should I be towing in tow/haul mode all the time? My concern is that in overdrive my crusing EGT is 900-1000F in od. I would suspect this to be because of the 35" high tires and the rear axle gear ratio of 3:73:1. So my question is, is it safe to run in tow haul mode until I reach highway speeds then I engage overdrive. Any hill I come across I always disengage overdrive to build boosts to keep the EGTs in check. I'm just concerned whether it would be hard on the trans. I have towed with my SD before but never any kind of weight that you'd actually feel behind you. I should also note that my truck has a powermax turbo, and a tow tune from gear head preformance.
Any input or insight would be greatly appreciated. Thank you in advance
Ryan
2006 Powerstroke 6.0
Blue spring mod
CAT EC-1
Coolant filter
Garrett Powermax turbo
Tuned by gearhead performance
MBRP 4" tubro back exhaust 5" rolled tip
4" ICON suspension lift
35" toyo MT's
BMF Novakanes
RY86 is offline
post #2 of 8 Old 06-18-2014, 12:05 PM
Vannnce's Avatar
Quoted: 13 Post(s)
I have a 7.3, so no tow haul on mine.... but with my work truck, i only use tow haul around town or if going down a pass and want to use it for braking. 900-1000 degrees is just fine, you can run 1250 all day long so long as you dont go above it for a long period of time.
You really wont even notice 5k behind you. Watch egt's and your tranny temp and you should be fine. So long as im on flat terrain i haul my fifth wheel in overdrive with no problem
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #3 of 8 Old 06-18-2014, 12:19 PM
Airborne CIB's Avatar
I run in tow/haul mode anytime I am towing. Tow/haul mode does not keep tranny out of O/D. Tow/haul just changes how the tranny shifts
john galt and R&Rpowerstroke like this.
Glendale, AZ
'05 F250 XL Extended Cab - 2 Wheel Drive, No Options Except: Integrated Brake Controller, 3.73 w/ Limited Slip, Upfittter Switches & AC
Added: Edge Monitor with EGT, Fuel Pressure, coolant pressure, low oil pressure system sensor & Ambient Temperature Sensors, turbo timer & back up camera. High Idle Mod. Manual Fan Mod, Power fold/power extend mirrors.
Installed: Cruise Control w/ Leather Steering Wheel, 17 Alloy Rims off XLT, 40 20 40 Vinyl Front Seats
Well maintained with Motorcraft parts, over 222k miles and still have original head bolts.
Airborne CIB is offline
The Following User Says Thank You to Airborne CIB For This Useful Post:
StarDriver (06-21-2014)
post #4 of 8 Old 06-18-2014, 12:33 PM Thread Starter
RY86's Avatar
Oh ok, thanks guys
Blue spring mod
CAT EC-1
Coolant filter
35" toyo MT's
BMF Novakanes
RY86 is offline
post #5 of 8 Old 06-18-2014, 01:35 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
Like stated above. T/H Will still shift into OD it just needs to be using less engine power before it will shift in and lock up the torque converter. It's quicker to downshift to keep from driving "under the turbo"
Sent from one of the worst apps in the world
john galt likes this.
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #6 of 8 Old 06-18-2014, 07:48 PM
Quoted: 6 Post(s)
I wouldn't use it. Waste of fuel in my opinion. No need to shift at 2500 RPM towing 5k
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #7 of 8 Old 06-05-2016, 10:45 PM
RiverSide's Avatar
Quoted: 4 Post(s)
I have Amsterdam to Malaga(spain) comming up next week.
same weight as the O.P Same tires and gear ratio.
to me it feels more natural to keep it in tow mode as the engine breathe more air and has better cooling.
But with our european diesel prices i do not wan,t to waste fuel so i wonder what would give a better Fuel mileage Tow mode or not, without frying the trans ofcourse.
I have the gearhead 8k tow tune i do not know if that helps or not.
speed limits 50 miles per hour,...that would not even kick it in OD in while tow mode.
When i push the Tow/haul button off it kicks in OD at 50/55 but at 1600 isch rpm,EGT Rise to 900 and it just doesn,t feel right.
Maybe 35 tires and a 3.73 ratio and a 4 inch lift is not an ideal set up for towing @ 50Mph
'05 F250 Harley Davidson Crew Cab'4x4 Powestroke diesel 6.0
ARP - Egr delete - Hpop upgrade - Blue Spring upgrade - Catepillar ELC EC1 coolant - Coolant Filter - edge Insight monitor- SCT Custom tunes - EGT & fuel pressure - Zone off road radius 4 inch lift - Dual steering stabilizers -Krank fuel 9x20 -rims - Clarion NX702E
RiverSide is offline
post #8 of 8 Old 06-06-2016, 05:28 AM
Heavy_GD's Avatar
Quoted: 1310 Post(s)
Feedback Score: 3 reviews
if you destroy any parts with 5k, you either need to slow down or you had issues before hand.
I dont use T/H unless I am doing a lot of braking.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
