Question about WD Hitch and Sway control - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 9 Old 06-10-2014, 11:07 AM Thread Starter
My wife and I just purchased a new travel trailer. My tow vehicle is a 2012 F250 CC SB Powerstroke.
Having towed since I first got my DL I understand the importance of safety first.
My question is do I need a WD Hitch or Sway Control Bar to pull this rig with my TV?
I'm not too concerned of the weight as much as I am the sway. This TT seems pretty light for it's size. If this were my 30' boat I wouldn't have a single concern because of it's weight and shape.
It's my understanding the 2012's come with Electronic Sway Control as part of the VSC/Advancetrac system.
Now obviously this is just a last resort feature to ever rely on.
So what would you guys do? Do you think I'm safe without it?
Here are the specs.
Specs for Keystone RV Passport GT
Model: 2920BH
Shipping Weight 5385
Carrying Capacity 1815
Hitch 625
Length 32' 10"
Height 10' 9"
SilverPowerStroke is offline
post #2 of 9 Old 06-15-2014, 08:45 AM
yes,you definitely need a WDH. Even though you list hitch wt as 625, that would be empty without whatever additional camping things you would add. Also these trailers tend to be goosie when passing or getting passed. Remember also that that 625 lbs. has a fulcrum effect as it is a good 4 ft behind the weight bearing area on the rear axle. Alond with the WDH, you also need at least one sway control bar.
2014 Blue Jeans blue F250 CCSB 6.7 Lariat w/Lariat ultimate pkg, chrome pkg, 3.31 E-locker FX-4 pkg, rustproofed/undercoated, Access Limited tonneau, Weathertech wheel well liners, Weathertech mudflaps, Linex matching blue bed liner, Enduraplas transfer tank, Air Lift 5000 airbags.
schrod is offline
post #3 of 9 Old 06-15-2014, 08:59 AM
Vannnce's Avatar
Quoted: 13 Post(s)
From pulling my moms 31' travel trailer with similar specs, id recommend a WD hitch. The trailer doesnt squat my truck at all, maybe half an inch, but with the bars on, it makes for a lot smoother ride and looses a lot of the tail wagging the dog effect. Ive hauled it with and without and its certainly more comfortable with it
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #4 of 9 Old 06-15-2014, 06:24 PM
hansel's Avatar
Quoted: 94 Post(s)
You will need a WD hitch, and the new one's today have good sway control built into them, they use the bar's as friction control for sway.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #5 of 9 Old 06-15-2014, 07:00 PM
sagebel's Avatar
Quoted: 8 Post(s)
I have a 31' TT and when I first got it used a single friction bar. It didn't work. I think I made two trips before I upgraded to a Reese Dual Cam WD hitch. I have heard a few dealers say that anything over 25' needs more than a single friction bar. The sway control is built it. Just got back from the Grand Canyon and had 30+ mph side winds the entire drive home. I was amazed at how well the trailer handled. Every other TT, 5vr, and tractor trailer that I passed was all over the road. There are a few other WD hitches that provide sway control.
2012 F350 DRW King Ranch FX4
Originally Posted by nighthawk285 View Post
Pull it sideways back and forth....and don't be gentle
Originally Posted by Six0~Stroker View Post
I was just planning on running over here and whipping it out. Sent from
sagebel is offline
post #6 of 9 Old 07-01-2014, 08:30 AM
Equal-i-zer WDH is the way to go. Even though these trailers do not make the rear squat, they will make the front end come up. The WDH will change get the front back down where it belongs. The Equal-i-zer hitches have the sway control integrated, so there is no need for a seperate system. It works very well.
Now, do you have to have it? Maybe not... But it is you and your families safety, so I would say it is worth every penny.
2014 F350 4x4 Lariat CrewCab ShortBed
2015 Palomino Puma 295BHSS
willieboy is offline
post #7 of 9 Old 07-01-2014, 08:37 AM Thread Starter
Well,
I figured I'd post an update here. Eventually I will need to get one.
The weight of the trailer is not an issue, the truck doesn't squat and the front doesn't lift more than 1 inch.
Steering is great. The issue is however this thing is a massive wall that easily get pushed around.
Anything over 60 mph and it wants to sway, actually the truck does more moving than anything. I just don't feel comfortable.
I'm currently looking at the Anderson No-Sway system. What would be the advantage or disadvantage over the Equal-i-zer brand?
post #8 of 9 Old 07-01-2014, 08:53 AM
Experience... The Anderson is pretty new, but by most accounts I have seen, it does seem to work well. The Equal-I-Zer has been around a long time, and there is a lot fo experience with people using it. The only downside the equalizer might have is that it can be noisy when doing slow turns in the campground. It groans something serious. They have addressed that issue with some updated design, so it maybe better these days.
post #9 of 9 Old 07-01-2014, 06:03 PM
hansel's Avatar
Quoted: 94 Post(s)
Originally Posted by SilverPowerStroke View Post
Well,
It sounds like your WD hitch is not set up properly, your front fender should return too it's unhitch height or within a 1/2". If your front fender is raised by 1" then you are light on the front axle and this will help cause the uncomfortable feeling along with the trailer.
Here are the steps I took when setting up my WD hitch:
1- Find a good level area
2- Measure the fender's directly over the axle's, I use a piece of tape as a mark
3- Hitch up the camper, you want the trailer slightly nose down, this is where a bubble level is handy.
3a- You might have too move the hitch head up or down on the shank, too get the camper nose down a hair.
4- Remeasure the fender (front)
5- Raise's too much, tilt the hitch head back this will apply more force back to the front axle.
Lower's the front, tilt the hitch head up this will take some of the force off the front axle.
Don't worry too much about the rear fender, it probably won't drop more than 1"-1.75"
I was having all kinds of handling issue's with my truck and camper until I found the Keystone RV forum and learned that my truck hitch was set up wrong.
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
