2014 F350, 31' toy hauler... WD hitch?? - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 9 Old 05-22-2014, 04:42 AM Thread Starter
Hello all. I ordered a Jayco Octane T26Y toy hauler about a month ago. At the time I owned a 2010 Toyota Tundra that I intended to pull it with. The max loaded weight of the trailer is right at 10k pounds but will usually be around 8500 loaded. It's 31' total length with 26' of living space and around 1000lbs on the tongue unloaded, slightly less loaded. Because the trailer was right at the limit for the truck, I ordered the biggest baddest weight distributing hitch with sway control that was available.
Fast forward a couple weeks... I just bought a 2014 F350 PSD to pull the trailer with. Now I've gone from having too little truck, to having something that is probably gross overkill for the trailer. My question is, do I still need the WD hitch? I know the truck has some sort of built in sway control and it's rated for more than 1000lbs on the tongue. Do you think I should go ahead and keep the WD hitch, or would the money be better spent elsewhere?
For what it's worth, this is the trailer in question:
and this is the new truck:
Flite is offline
post #2 of 9 Old 05-22-2014, 05:03 AM
07upbandit's Avatar
Absolutely go with the wd hitch
97 F250 HD Ext cab, LB (Sold and missed)
Banks Power Pack
07 F250 CC SB Outlaw
Studs
Black Onyx HG (OK so far)
Sinister EGR cooler
Sinister Oil cooler
Red Head Steering box
07upbandit is offline
post #3 of 9 Old 05-22-2014, 05:43 AM
Quoted: 365 Post(s)
Feedback Score: 5 reviews
Get the new style WD Hitch. The one without the chains. It is SOOO much better than the older models with the chains that you hook to the trailer.
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
post #4 of 9 Old 05-22-2014, 05:56 AM
You won't "need" but it's good to run it. I.E. for moving it across town or something short I wouldn't waste my time hooking it up. For a long trip I use my WD slightly taught, not super tight like you see on the road.
FWIW I have basically the same TH just older model so probably weighs more, and I've towed it 30-40 miles loaded/unloaded with my 250 with no issues, no sway, nothing.
I do however prefer to use the WD like I said, lightly applying pressure, same with the sway control, just enough to take a tad off the front.
You'll love how the new truck pulls taht thing, will be soooo much better.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #5 of 9 Old 05-22-2014, 06:02 AM Thread Starter
Well... I never even got to tow it with the Tundra, but I did tow a 20' enclosed car trailer regularly with it. Those Tundras are good pulling trucks for a 1/2 ton, but they're not even on the same planet as what I have now.
Flite is offline
post #6 of 9 Old 05-22-2014, 10:27 AM
SuperCrutyPS's Avatar
Quoted: 312 Post(s)
Garage
Congrats on both vehicles! Lookin' good!
If it were me, I'd use the WDH since I got it. IMO, every bit helps.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is offline
The Following User Says Thank You to SuperCrutyPS For This Useful Post:
Flite (05-24-2014)
post #7 of 9 Old 05-27-2014, 10:57 AM
Quoted: 11 Post(s)
Keep the WDH. It makes for a more comfortable tow because otherwise the front end will feel light. I have a 2013 F250 PSD and I've towed our 8K pound travel trailer with and without a WDH. Without the WDH, the front end felt light and would move around. With the WDH, the truck feels a lot more planted, noticeably so.
Whether you decide to keep the WDH or not, load up the TT and see how close you are to the rear bumpstops. If it's less than 2 inches, you may be a good candidate for airbags. I just installed some and my TT rides noticeably better, although mine has 1200 pounds of tongue weight, which is on the heavy side for a TT.
Drewtk is offline
post #8 of 9 Old 06-15-2014, 06:07 PM
sagebel's Avatar
Quoted: 10 Post(s)
You will be surprised at how easy it is to squat the rear of the newer trucks. As mentioned earlier, get a WD hitch with built in sway control. I run the Reese Dual Cam WD hitch. There are others so shop around. A single friction bar will not be enough for your trailer.
2014 CCLB 4x4 Lariat Ultimate
sagebel is offline
post #9 of 9 Old 06-15-2014, 07:35 PM Thread Starter
I got the big equal-i-zer hitch. It's a beast, but it does make towing REALLY nice.
Flite is offline
