2001 F-250 SD 7.3 - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
 1Likes
post #1 of 11 Old 04-15-2014, 05:50 PM Thread Starter
2001 F-250 SD 7.3
Hey Guys
I have read over and over the towing threads - so please be kind....
2001 F-250 SD 7.3. Rebuilt engine with .30 over, rebuilt tranny with HD parts (less that 15k on both) cold intact, 4"exhaust, 9 quart over stock transmission pan and a pac brake and new HD springs on the rear
I have a change to buy a 38' Work and Play Toy Hauler - 5th wheel
16k weight on the trailer
what do you think? Will my truck be ok pulling this?
I'm thinking I would need to add bully dog and something to keep track of EFCs and temps.
What else would I need to consider adding?
hherifor is offline
post #2 of 11 Old 04-15-2014, 06:06 PM
Quoted: 27 Post(s)
Air bags. Is the bully dog for a monitoring system or a performance add on? Maybe a bigger trans cooler. I'd get some gauges. EGT, trans, boost at least. I might even spring for fuel, oil temp and coolant temp if you plan to tow this a good bit. I don't have experience towing this big on srw but I would think some would say a dually is better for stability reasons. Personally I think it will be fine.
strokin-7.3 is offline
post #3 of 11 Old 04-16-2014, 07:23 AM
jesilvas's Avatar
Quoted: 2 Post(s)
You will be over legal weight most likely.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 11 Old 04-16-2014, 12:55 PM Thread Starter
Im just looking at the bully dog for monitoring - I really do not want all those gauges if I can get away without them.
Do you think I will need the air bags, as I have just replaced the rear springs with HD Springs (not helper springs)??? I do have a pac-brake already (love it) so if I do add air-bags I will go with them
hherifor is offline
post #5 of 11 Old 04-16-2014, 01:46 PM
That is a lot of trailer for a 250
BRAD6160 is offline
post #6 of 11 Old 04-17-2014, 07:07 PM
Vannnce's Avatar
Quoted: 13 Post(s)
only on paper, besides gears its the same as a srw 350. airbags are nice, id recommend them.
is 16 the dry weight or gross? You wont go anywhere in a huge hurry but it'll sure get there
Ask 7.34ever (Brandon) He used to haul a bigazz trailer with a 7.3 250. If i remember right he said it hauled just fine besides being legally overweight
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #7 of 11 Old 04-18-2014, 07:44 PM
StarDriver's Avatar
Legally overweight.
You guys can run overweight, but when you get in an accident, and the lawyers find out you're overweight, you'll be paying that lawsuit off the rest of your life.
TurboMustang370 likes this.
2006 F-350 4X4 FX4 Tuscany Longhorn , Leer Custom bed cap, RECON lights, Upfitter switches, Whelen Lighting, Hi-Idle Mod.
Instructor at B.R.A.K.E.S (
28 years Commercial Driver.
StarDriver is offline
post #8 of 11 Old 06-26-2014, 10:48 PM
vandy's Avatar
Originally Posted by StarDriver View Post
Legally overweight.
Ok StarDriver. I'm going to hijack a bit. How are all these guys towing these big hog 5th wheels? I don't see many f450s on the road. We are in the market and seems like most are over my "legal limit"? Are that many just towing illegal?
vandy is offline
post #9 of 11 Old 06-27-2014, 04:42 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Yes. Either because they don't care, but most just don't know. "Well, Bob pulls his 42' Continental Coach with an F250 and said it did fine."
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 11 Old 06-27-2014, 04:44 AM
vandy's Avatar
I asked a guy I work with about it. His theory was if it truck could pull it, he would move it. Showed me a pic of his f350. His leaf springs where bent backwards
vandy is offline
