Need Help Moving Broken F350 - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 4 Old 03-29-2014, 05:38 PM Thread Starter
I have a 2003 SD Short Box Crew Cab 4x4 that is Broken and need to tow it home about 500 miles. Anyone know what size trailer I need to rent to move my truck home. Will a car Dolly work? Thanks for your help.
Drotsma is offline
post #2 of 4 Old 03-29-2014, 05:50 PM
Rodslinger's B1TCH
it's too wide and heavy for a u-haul dolly
an 18' flatdeck that is 10,000lbs GVW will work fine. i don't think u-haul has one big enough. you might need to rent one from a heavy equipment dealer
steve604 is offline
post #3 of 4 Old 03-29-2014, 05:52 PM
White Noise
AU7POINT3's Avatar
Quoted: 2 Post(s)
8000 lb capacity trailer plus vehicle and fuel to pull it, very $$$. Long-distance tow truck w/ roll-back bed, very $$$. Car dolly also $$$ may not be rated for weight of SD, but if so, take out your driveshaft so you don't overheat the transmission. Auto transport service could do it, but again, very $$$. Best to probably fix the truck (which has to be done anyway) then drive it home. There are also threads where other PSD / and diesel bloggers haul stuff for each other. Where is it located and where does it need to go?
2002 F-250 LARIAT CCSB 7.3 AUTO 4X4 261,XXX
2004 EXPLORER XLT 4.0 AUTO 2WD 130,XXX
1966 MUSTANG COUPE 289 4 brl V8
IN-LAWS...
2004 EXPLORER SPORT TRAC 4.0 4X2 100,XXX
2004 F-250 RCLB 6.0 AUTO 4X2 38X,XXX
2005 F-250 RCLB 6.0 AUTO 4x2 36X,XXX
SOLD... 3 RANGERS, 3 F-150s, 3 F-250s, 96 COUGAR 4.6, 99 EXPEDITION 5.4, 65 66 AND 69 MUSTANGS
RE-ASSIGNED... MULTIPLE FORD POLICE INTERCEPTORS
AU7POINT3 is offline
post #4 of 4 Old 03-29-2014, 06:39 PM
Rodslinger's B1TCH
It's too wide and heavy for a dolly. I think they're only rated for 4000lbs and 6' wide. My tacoma barely fit on one and 33" tires were too tall for the straps.
steve604 is offline
