Tow capacity? - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 13 Old 03-15-2014, 04:14 PM Thread Starter
Quoted: 5 Post(s)
Tow capacity?
I have a 2004 F350 6.0 4x4 which is undergoing a full bulletproofing-oil cooler,egr cooler,water pump,hpop,ficm,arp studs. I understand my tow capacity according to Ford is 12,700 for my truck. Im looking into purchasing a
Fifth wheel trailer with a max capacity of 14,000lbs. Do I need to be concerned? I think most rigs out there afe in this range or more seeing as though this is only a 35 foot trailer.
Thanks for any input!!
Redrider007 is offline
post #2 of 13 Old 03-15-2014, 05:51 PM
Quoted: 27 Post(s)
If the trailer and the cargo in it combined is 14,000 pounds than I'd say you're fine. If you're over 26,001 pounds you need a CDL. What cab configuration do you have and SRW or DRW?
strokin-7.3 is offline
post #3 of 13 Old 03-15-2014, 05:55 PM Thread Starter
Quoted: 5 Post(s)
Crew cab srw 4x4
post #4 of 13 Old 03-15-2014, 06:11 PM
Quoted: 27 Post(s)
You should be ok. If rear end sags when loaded look into air bags.
post #5 of 13 Old 03-15-2014, 07:07 PM
Vannnce's Avatar
Quoted: 13 Post(s)
you'll be just fine. the biggest things are your comfort zone and your trucks ability to stop it. Have good trailer brakes. thats similar to my 5'ver that i haul with my 02 and it hauls/(stops) without any problem at all.
CDL rules IMHO have so many shades of gray. I have one myself so i dont worry about it... but like stated, anytime youre near 26,001 your getting in to shady territory without one
but 7500+14000= 21500 and i roll that state to state all the time so i wouldnt worry about a thing
-Vance-
.2002 f350 Lariat 4" lift w/ 35's. Hydra w/PHP. Swamps 175/146 injectors. gauges. banks power elbow, 4" dp 5"out,RiffRaffs FRX ww, ccv, AIH delete riff raff boost port, '10 tailgate mod amongst a bunch of other goods
.B&W turnover/ companion to haul my 2001 Prowler 5'ver. Home away from home
I.B.E.W. Local 1002
Vannnce is offline
post #6 of 13 Old 06-04-2014, 04:25 PM
Quoted: 2 Post(s)
I'm not trying to hijack a thread here but I have my manual open right now. It says max gcwr is 23000 for my truck. My maximum gross trailer weight is 12500. Is that for the factory under the bed hitch system? I have a gooseneck and I know I'm exceeding that. I guess what I'm asking is I know my truck is right around 8000# full of fuel and me. If I take my gcwr and subtract that I'm left with 15k of possible trailer weight. So if I have a gooseneck that weighs 15k I'm still legal by sticker right? Just trying to understand this lol
bigchad93 is offline
post #7 of 13 Old 06-04-2014, 07:15 PM
Quoted: 27 Post(s)
I don't think they look at gcwr as much as they do axle and overall weight. IIRC I actually think in the manual in states "recommended" gcwr. I don't think the gcwr is on the door jamb sticker but I know the gvwr and axle weight ratings are. Was stopped by state patrol once for 13 mph over in work truck (f-450 dump bed). He asked the gvwr and than checked the sticker himself. I saw him glance in back of truck and saw I had a railroad tie and some tree limbs. Guess he didn't care to scale me at that point lol. Has DOT numbers so maybe that's why he checked idk
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
post #8 of 13 Old 06-04-2014, 07:18 PM
Quoted: 2 Post(s)
So if I don't go over 26,001 combined or over 6k rear axel weight I'm fine? This is all for my knowledge and understanding. Most I have thrown behind the truck was 14k.
post #9 of 13 Old 06-04-2014, 07:40 PM
Quoted: 27 Post(s)
check your states laws, but that is my understanding. under 26,001 without CDL and make sure you don't go over any axle weights including the trailer axles.
* I see star driver is viewing....he'll know better than me
-Kris
4'' straight pipe
DIY 6637
38r
post #10 of 13 Old 06-04-2014, 08:05 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Here in Ga if your under 26,001 your good (according to my class C license) but keep in mind about manufacturer weights and to not exceed that without proper endorsement and licensing they objective goal is safety for you and those around you, so if your under the max class c weight and hauling on personal use your fine
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
