Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > Towing, Hauling & Diesel Competition
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
Old 10-19-2008, 09:08 PM
daboostcreep daboostcreep is offline
Want to raise my trailer height. How to?
I bought an open trailer 6.5'x10'. The trailer is kind of low for what I want to do with it. I'd ideally like to lift it 1.5" or 2". My setup uses leaf springs that are 1.75" wide and u-bolts. I'm wondering if lifting it with blocks is possible, and where to get them. Of course larger tires will be following so that I can get more ground to axle clearance.
Please point me in the right direction.
Old 10-19-2008, 09:13 PM
forddieseltweek forddieseltweek is offline
I do it all the time, Just do a spring over on it... Weld the spring purches on top of the axle and put the axle below the springs... Its the safest wat to lift a trailer..
Old 10-21-2008, 08:14 AM
The axle is already below the springs.
Old 11-24-2008, 02:00 PM
icedevil icedevil is offline
Some people will use a 2" channel or heavy wall square tubing and remount the spring mounts, basically putting more distance between the spring mounts and the frame. If this is your route, make sure your axles are measured out perfectly when they get welded back together or your trailer will wear tires out
