OBS tow question - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 25 Old 12-23-2013, 01:53 AM Thread Starter
vandy's Avatar
OBS tow question
Im in the market for a 5th wheel. i bought my truck with the intent to tow a tt or 5th wheel with it. The truck is stock to the paper air filter for now. My "plan" is to have stage 1 injectors intake tune exhaust intercooler gauges with rear air bags and a good brake controler. But here is my question, am I still asking too much of my truck? The unit im looking at has a GVWR at15500lbs. Dry weight is 12999lbs. From what I can find my tow rating is 10k. Am I really going to need more truck to move this pig down the road safely?
Oh and ive got an auto with 3.55s so those are going to have to go also
vandy is offline
post #2 of 25 Old 12-23-2013, 04:24 AM
Diesel_brad's Avatar
Quoted: 4 Post(s)
The GCVW of your truck is 18,500 w 4.10 and 15,000 w 3.55
Your truck EMPTY weighs a MINIMUM of 6500. then factor fuel, you, family, gear etc you are 7000-7500.
Subtract your truck weight from the CGVW and that leaves you
11,500 on the high side and 7500 on the low side.
I think you are asking TOO much looking at a 5th wheel of that size.
YES your truck will pull it. It will NOT like it, nor will you
My trucks CGVW is 20k(4.10s and stick) and I grow out at 20-22k frequently. But I also have bigger injectors, exhaust, intake, chip, etc and it does well, but it aint no rocket ship
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #3 of 25 Old 12-23-2013, 04:41 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I've pulled 19,700 and my truck is bone stock (well it was when I did that) down to a down pipe only, look into gauges, better gearing, and just make sure that's what you want, your truck should pull fine, won't be the fastest on the road but won't be to bad either
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 25 Old 12-23-2013, 04:57 AM Thread Starter
vandy's Avatar
Gauges, trans and egt will be a must if im towing anything but local. With that much weight the 4:10s will be replaced prior also.
I guess my question is my truck comes with a factory rated tow capacity. Im gueasing that was based on factory equipment. So if I upgrade things like sticks, cooling, braking , gears and or transmission, should in theory change my trucks tow capacity? Or is that based on a structural ability of my truck?
Im just having a hard time swallowing that my f350 7.3 diesel has about the same factory tow capability as a current f150 ecobust
vandy is offline
post #5 of 25 Old 12-23-2013, 08:26 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You can build it up to tow that weight but in some states you could be considered overweight esp when you find out that the 5th is much heaver than what the salesman tell you.
Look up OLD Outlaw posts and what all he's done..we build it up for him and he's towing Heavy.
CT Performance, Inc. is offline
post #6 of 25 Old 12-23-2013, 01:39 PM
Quoted: 6 Post(s)
I say re-gear and your good to go.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #7 of 25 Old 12-23-2013, 01:46 PM
dr.deere's Avatar
Quoted: 19 Post(s)
After a regear you can tow that much now prob. Like previously said you will be slower off the line than a new truck but I've run 70 all day with that kind of weight just fine. My state does not bother non placard rigs. And I hold a cel and health card so I don't worry bout it too much with a good brake controller I've not had an issue stopping either and I've owned new pickups before to compare
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #8 of 25 Old 12-23-2013, 02:16 PM
Quoted: 6 Post(s)
Your truck will handle that weight just fine now, but I would want 4.10 gears to make it easier to pull.
I pull a 9000 pound horse trailer almost every weekend with a 3.73 rear. Twice a year I pull 18-20k pounds hauling hay.
Videos:
avfrog is offline
post #9 of 25 Old 12-25-2013, 09:08 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
My ecoboost has the tow package and it's factory rating is like 17,500
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 25 Old 12-25-2013, 09:55 AM
Quoted: 3 Post(s)
Nothing can ever be done to change the gvrw of any vehicle, even putting in F550 axles and suspension.
