gooseneck or bumper pull 2 car trailer - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 16 Old 12-19-2013, 05:46 PM Thread Starter
SPY+'s Avatar
ok so i have an opportunity to tow 2 cars once a month from phx to LA
i drive a 2010 ccsb 2wd srw 6.4
what i am trying to decide is either buy a 2 car bumper pull trailer or a goose neck trailer.now i know it would be better if i had DRW but i dont so what i am trying to figure out is what is the best choice for my truck and for safety
i would like your guys thoughts on the matter and what you think is my best option
thanks for reading
SOLD:00 F250 CCSB LARIAT 7.3 4'' MBRP TURBO BACK, AIRAID INTAKE, GAUGE POD, INTERNATIONAL UP PIPES,TRANSMISSION COOLER KIT,ADRENALINE HPOP
NEW: 2010 f250 6.4 stock
SPY+ is offline
post #2 of 16 Old 12-19-2013, 05:47 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 278 Post(s)
goose neck all day long.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 16 Old 12-19-2013, 05:59 PM Thread Starter
SPY+'s Avatar
thats what i was thinking but the only thing i am kinda worried about is weight in AZ you can tow up to 26000 with out a cdl.
goosenecks are alot heavier then bumper pull trailers and with two cars i am a little worried about going over the maximum weight allowed
SPY+ is offline
post #4 of 16 Old 12-19-2013, 06:14 PM
If you pulled with both trailers, you would pick goose neck all day.
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #5 of 16 Old 12-19-2013, 06:15 PM
jesilvas's Avatar
Quoted: 3 Post(s)
With an F250, you'll be over your GVWR most likely, and probably GAWR of the rear. If it's for profit then you need CDL and DOT stuff.
You'll at least need an upgraded license.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 16 Old 12-19-2013, 06:20 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
The goose neck will tow smoother for sure. It will also tract 1000 times better in the wind. There's a reason all of the big rigs running down the road run a 5th wheel set up.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 16 Old 12-19-2013, 06:43 PM
marshal.smith7's Avatar
Goose neck hand down
marshal.smith7 is offline
post #8 of 16 Old 12-19-2013, 07:23 PM
Duncan's KR's Avatar
As everyone else has said a gooseneck or fifth wheel trailer will pull better then a bumper pull style will mainly because of the fact that that the load is over the top of the axel and not behind it. As for the trailer there are several different options out there from a low-boy style to the axel over style equipment trailers it really all matters on how much you want to spend. The other thing I would suggest is some proper tie downs for your cargo, I have hauled and pulled trailers all my life and it was not until these last several years I learned right from wrong. I prefer Mac's tie downs but that is just my opinion.
Regards,
Duncan
2005 F250 King Ranch (Modification list made)
2006 Jeep LJ "Just my little heap that I like to creep"
Duncan's KR is offline
post #9 of 16 Old 12-20-2013, 03:25 AM
You should be able to haul 2 cars on a GN and still easily stay under CDL,
Spudman is offline
post #10 of 16 Old 12-20-2013, 05:18 AM
Fire From the Clouds!
Horizon122's Avatar
Quoted: 116 Post(s)
A gooseneck is obviously a better choice being as the ride will be smoother and the trailer will be able to take more/heavy loads. But that also means buying a 5th wheel/gooseneck hitch and having it installed as well as the trailer weighing more.
I only tow with a bumper pull trailer which is a tri-axle beaver tail trailer and the only heavy load I put on it is a mini excavator which weighed about almost 8,000lb's and never had a issue but then again I have a F350.
2002 Ford F350-Lariat-CrewCab-LongBed-7.3L PowerStroke Intercooled Turbo Diesel!
2.5 Pro Comp lift on 315/75r16 Fierce M/T's
Enough Stuff To Pull Yours!
Horizon122 is offline
The Following User Says Thank You to Horizon122 For This Useful Post:
WD40 (04-14-2014)
