what style truck to get? - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 8 Old 11-23-2013, 08:44 PM Thread Starter
i'm not an owner YET, lol
i'm shopping around, but I have a few things that are a must.
4x4, crewcab. power everything, with a manual transfer and lockouts.
this truck will be used as a daily driver, except in the near future I'll be getting a 5th wheel camper (late 80's early 90's) and i'll be hauling a 20ft car hauler with a good size tractor. also the occasional gooseneck around hay season
it will be a used truck,05-09 years,
but I'm not sure on what engine yet, 6.0l or the 6.4l? i'm looking for the best fuel mileage, good power, i'm also thinking a cummins(but I hate the truck they are in....)
also i'm not sure if I would need the shortbed or longbed, I like the shortbed for ease of maneuverability, but like the longbed because I can put just about anything in it, and I know I won't have any 5th wheel to cab problems.
any input would be great,
thanks
fordtrucknut is offline
post #2 of 8 Old 11-24-2013, 07:09 AM
Quoted: 6 Post(s)
That's all personnel preference. You can pull 5th wheels with a slider hitch if needed in a short bed. Mine is a short bed and I don't have any complaints. I can turn a gooseneck past 90 degrees no problem.
2006 F250 Lariat FX4 6.0 PSD
Performance: EGR delete, SCT tuned, 5" straight pipe, blue spring, 03' turbo
Other mods: Nathan Airchime K5HA locomotive horns, high idle mod, fog light mod
Videos:
avfrog is offline
post #3 of 8 Old 11-24-2013, 06:44 PM Thread Starter
i've narrowed it down to two trucks, one longbed one short,
shortbed is an FX4 Lariat, with electronic transfer, but it is fully loaded with a ball in the bed. NO aux switches, 155,000 miles, 1 owner $22k
longbed is an XL, nicely equipped, has the manual transfer. tow package with the aux switches 140,000 miles $19k
any input???
shortbed
longbed
post #4 of 8 Old 11-24-2013, 06:55 PM
Firewood Hack
Locust Cutter's Avatar
Send a message via MSN to Locust Cutter
The long bed will distribute the weight better and handle better. The Short bed, will turn better and has nicer shocks, (and a bit nicer interior). If you plan on running a tool box, factor that in as well. The long-beds also have larger fuel tanks which are nice when traveling down the road. The short beds are obviously easier to park when un-loaded. Which is more important to you?
Bryan TAPS Member
TSgt KSANG
Computer guy now, but former B-1b and '135 Crew Chief
"IYAMYAS" -"Kicked the tires and lit the fires!!!"
'03 F-250 6.0/5R110 4x4 RC/LB, 4" diamond eye exh, SCT X4, EGR missing, ARP studs, new oil cooler... (joint venture between Dad and I)
'02 F-350 CC/LB Flatbed Dually 4x4, 7.3PSD/ZF-6 -WW2, gutted factory exhaust, F.F. Stage 1's, 6637 filter, TS6 w/tunes by Matt and gauges.
'01 f-350 gasser/hand shaker 2wd - Burned to the ground
Locust Cutter is offline
post #5 of 8 Old 11-24-2013, 07:05 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
Aux switches can be added easily, the wire loom is under the dash and u just need to buy the switches. I like the short bed better.
Edit: I've owned both long bed and short, if your gunna do any kind of lift with bigger tires I say long bed- they look way better IMO than a shorty with bigger tires and lifted. If your gunna leave it stock height and stockish tires then go with the shorty.
Here's a pic of my old 6.4 with a leveling kit and 35's.
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #6 of 8 Old 11-24-2013, 07:24 PM
mts678's Avatar
Quoted: 12 Post(s)
2017 f250 platinum
mts678 is offline
post #7 of 8 Old 12-01-2013, 10:10 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
I park my cclb Dually up front at my local grocer, it's scratched dented and old so I don't worry much, but I'd get the long bed if you have that much to haul and seems like your gonna be hooked up a lot, the short bed is obviously better equipped with amenities tho
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 8 Old 12-13-2013, 09:23 AM
sledneck3's Avatar
Haven't personally owned a 6.0L or a 6.4L but a friend of mine has had nothing but issues, breaks down everywhere he hauls with his 6.0L. 6.4L is a power house but you're going to suffer in fuel mileage. The Cummins are good, I'd go 01-03 personally if you're going to go that direction. I've hauled with both a short box and long box; as a daily driver its nice to have a short box, fits in more places, easier to park and turn around but if you know you're going to be doing a lot of hauling the long box is going to be a better choice, plus you have more bed room for other stuff (tool box and miscellaneous crap) when you're hauling a gooseneck trailer. Heavy loads and long distances I'd say check out a dually, though not needed, its gonna haul nicer. Basically it comes down to personal preference. Good luck
sledneck3 is offline
