Wiring problem - Ford Powerstroke Diesel Forum
Towing, Hauling & Diesel Competition Discussion of Powerstroke Usage EG. Towing & Hauling Habits, Off Roading , Diesel Drags, Sled Pulls, ect...
post #1 of 4 Old 09-21-2013, 05:39 PM Thread Starter
Wiring problem
I have a 2011. Superduty. Having trouble with trailer brakes working on my flatbed trailer. Everything except trailer brakes works perfect lights,blinkers,brake lights. When I plug in to truck it says trailer disconnected. When I check voltage on plug on the truck I can read voltage on everything except trailer brakes.
Thanks for the help
rdeckard is offline
post #2 of 4 Old 09-21-2013, 05:59 PM
Heavy_GD's Avatar
Quoted: 1326 Post(s)
Feedback Score: 3 reviews
have you ruled out the trailer? I had a problem with mine and it was corrosion inside the plug on the trailer.
By inside, I mean removing the screws and taking it apart.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is offline
post #3 of 4 Old 09-21-2013, 06:35 PM Thread Starter
That was my next step. It just seemed funny I could not read voltage on the truck inlet
rdeckard is offline
post #4 of 4 Old 09-21-2013, 06:46 PM
Heavy_GD's Avatar
Did you have someone activating the booster in the truck while you were testing?
I can't remember if the harness needed to see ground for it to work but I chased a similar issue and even swapped the boosters before I found it.
GD
Heavy_GD is offline
